1 / 1 TRUCKS FOUND TODAY (6/20/23)
tripleB
TRX Guru
Arkansas
21' TRX 🦖
1084 Build Sheets found today, 6 of them were TRX. 1 more forum member with a truck starting production! Congratulations to @Tony379TRX
Found 157 Window Stickers tonight, 31 of them were TRX. 1 more forum member with a truck on the way! Congratulations to @JunyTRX4
VINBSWSBStoWSETASTATECOLOR
558735 @CoopFRAME6/26/2023VABlue
591652 @JunyTRX4XX127/13/2023IowaBlue
671449 @Tony379TRXXN/AColoradoCeramic
@tripleB TRX tracker shows I am "E" status. Granger told me last week they show me as "i" status. The RAM tracking site shows ETA of 7/12 at the dealer, but Granger says the ETA is TBD. I'm just trying to figure out what is the most accurate info. It seems like there are multiple tracking systems that are not in sync with each other. Any insight on the different status?
Dealer always has the most up to date data. There are only 6 status codes made available publicly (C, D1, E, KZ, KZM, KZX) So once you go to E status you wont see anything else until it is compelted and moved to KZ status. The dealer can see everything in between.
Got it. Thank you TripleB!
Perhaps that is the reason I haven’t seen my status update yet on the Ram Tracker. I will keep checking. Thanks triple b.
The status code wont show up on the RamTracker, its just the wording used. In your case you have a VIN listed but have not started production so you are in D status. Once your tracker moves to "In Production" then you are in E (Frame) status.
So is there a differ between “D” status and “D1” status that I am in now? As I see others in that status on the Ram Tracker. Thanks Triple B for your help.
I believe "D" means order is confirmed and accepted, and "D1" is scheduled for production from my understanding. And then like tripleB said above, once you actually start production you move into "E" and so on until the lovely KZX status lol.
Thanks for your reply. That makes sense.
@Dark Wing when you go D1 you get an estimated ship date. Dates get moved around but at least you have a rough date for when it’s scheduled for production.
tripleB's post here explains a lot.
