I've been receiving some questions about my build, so I've decided to consolidate all the information in one place for others to reference. There are a lot of minor details that I left out to try and keep the post as short as possible. Feel free to reach out and ask any questions.
Performance:
The new setup is broken in now. I still have a lot of tuning to go, but so far I'm cleared for WOT pulls on 93. I will continue to update this thread as I go on my journey of trying to see how deep into the 9s this setup with take me. I expect the Kong 2650 to be the limiting factor at this point.
You can find more pictures of my build on HHP's Instagram:
Performance:
- HHP/BES 426 boHEMIth Long Block
- Thitek Heads
- HHP Racing Custom SR(Street/Rumbler) Camshaft
- Billet Main Caps
- Callies Magnum Series 8CWT Stroker Crankshaft
- Sipple Max Effort 8HP95
- Billet Input Shaft
- 2600 Stall Torque Converter
- Billet Converter Mounting Pads
- ATI Hemi Flexplate
- Mishimoto Transmission Thermal Bypass Valve Kit
- Kong 2650 Supercharger
- Kong 130mm Throttle Body
- Nick Williams Upgraded Hellcat Bypass Valve
- ARP Stud Kit ARP-400-8025 in conjunction with FI 0.5" Hellcat Blower Spacers
- FI Thermal Blanket
- AAD Adjustable Idler
- Injector Dynamics 1750cc Injectors
- JMS Fuel Pump Booster
- Temporary until Fuel Injection Depot releases their triple-pump returnless style fuel kit for the TRX.
- Satera SENSORED Flex Fuel Harness
- Requires some custom modifications, mainly extending wires and tapping into your AAT sensor, to get it to work with the TRX. It is supposedly plug-and-play for the Challenger and Chargers.
- The only way for sensored-flex tuning without needing to go to an aftermarket ECU.
- Kooks 2" Long Tube Headers with Green Cats
- I sent the headers off to Swaintech for their proprietary "White Lightning" ceramic/aluminum coating.
- Paired with the Borla Atak catback and Borla exhaust tips. I no longer experience the infamous exhaust "chirp" with this setup.
- FI Stage 2 Interchiller
- Pierburg CWA400 Intercooler Pump
- FI 3-Gallon Reservoir
- FI Normally Open Solenoid
- Tuned by Zdung Ho!
- RB Performance Brakes 18" Caliper kit with lightweight, two-piece rotors.
- They eliminated my biggest frustration with the factory brakes, where they would heat soak very quickly and start to fade. I have yet to experience brake fade with the RB kit.
- ADD Baja Bomber Front Bumper
- Paired with 3x Yellow Baja Design LP6s and 2x Baja Design Squadron Pro Yellow SAEs for the fog lights.
- ADD Baja Bomber Rear Bumper
- Paired with 2x Baja Design Squadron Pro Wide Cornering Yellow lights.
- Line-X
- Covers bumpers, fender flares, side steps, and rocker panels for a two-tone look.
- Hot Start:
