Possible short?
Salinasjohn
Whittier , CA
jeep
Anyone else experience right door intermittent electrical problems?
Window won’t roll down, mirror has mind of its own, lock button won’t work.
None of controls work from driver side for only right front door. Everything else works fine.
It happened once when I let the truck sit in my garage for a few days when I was on a trip. Worked normal for a bit. Now, today the window does works but mirror operations seem normal.
Maybe it's the door module or the buttons themselves, haven't experienced anything like that. You can probably remove the door panel and check all wires/connections
Make sure your grounds are tight. One behind drivers kick panel for bcm and door, by battery ect. I think one behind passenger kick as well. Signals are over can so might be something on the network it doesn’t like… like a garbage tazer 🫣
No tazer!
Just igla that I’ve had for 2 years
IGLA has no control over any of that, tazer can so thats why I mentioned it. Sounds like a loose ground. Dodge “Ram” 🙄😆 likes to put grounds on painted surfaces.
If I could find my Tazer, I would unmarry it in a heart beat.
@Salinasjohn curious, do you have AMP steps installed? Just went through a similar issue.
Pull the headlight switch out, look down to the right or look up from the bottom and you will see it hanging there. To unmarry it you need to follow the crappy instructions online.
