HOT! Just added (4) Rigid 360 Series LED Lights to the Ram Bar on our TRX!
Johnny@JustBoltOns
TRX Maniac
Central Florida
2005 Mustang V8 Swapped / Insane Long Mod List.
We finally had a chance to mess with the Ram Bar (removed the silly foam inserts restricting wiring from passing through) and installed (4) Rigid 360 Series Lights, 2 White / 2 Amber. If you plan to add lights to the Ram Bar, do it before you install a bed cover or any other accessories as we had to remove all that and take apart the Ram Bar to get the wiring all neatly ran.
You can order these lights right here: https://justboltons.com/search-results-page?q=360-Series
Forum Discount code is RAMTRX (if it shows an inventory #, then we have them in-stock)
Mounting Brackets we ordered from axiaalloys.com as I didn't want to run the KCs or Mopar OEM mounts with these and the Amazon option posted on the forum was on b/o as well.
It's amazing how bright these 360 Series light and the backlight looks neat. We are tossing the idea of adding 2 more, for some reason it doesn't look right to us yet.
We'll get better pictures soon, took her on a 3,000 mile road trip this week!
Thank you! I am definitely debating on adding two more.
Just added two more, can't decide if I should run all amber caps yet.
