What URL are you using? The Vin has to be all uppercase and the checksum digit is not the same among all vins (that was my mistake when trying). If you made BBB's report, you should be able to see it. You have to clear cookies and cache between each check.I see it was posted that my window sticker was created, however I can’t pull it up yet on the site where you enter it. Do I just need to wait a bit yet?
Thanks,
Mike
Got it man, thanks!What URL are you using? The Vin has to be all uppercase and the checksum digit is not the same among all vins (that was my mistake when trying). If you made BBB's report, you should be able to see it. You have to clear cookies and cache between each check.
Drop your vin in uppercase after this:Do you have that link?
I tried it for my current truck and it came up with VIN not found. I do not believe I put it in all caps though and now of course, I have lost the link....
If @tripleB scan picks it up then you should be able to see it. Clearing cookies and cache between each check is key too.
