robbywoods.com
that's for the whole fenders, i just want to change the flares as cited in the previous post.Have you been living under a rock? Robby Woods are quite pricey, but there are other choices available.
2021-2024 Dodge Ram TRX Fenders - 2.5" Bulge
Bulge Rise 2.5" 1" Works With Your Stock Hood & Headlights Works With Stock Side Vents Ties Into Stock Extensions Includes: Driver & Passenger Fenderswww.fiberwerx.com
RAM TRX Carbon Fiber Body – Robby Woods
The TRX carbon bodywork is the byproduct of over 800 man-hours of labor. Although we’ve incorporated CAD design into a small part of the design process, we believe that there is a look that can’t be achieved by computers. RW and team first build the high-performance long-travel suspension, then...robbywoods.com
Ah, I see what you're talking about. Never seen anything like that on the TRX. Good luck with your search!that's for the whole fenders, i just want to change the flares as cited in the previous post.
Trying to put similar setup to my previous truck like these.
thank sir! I ordered a set of these Rebel Husky Liner ones and will try to modify them to fit. From what I understand Rebel has the closest to TRX dimensions in the front, but they do not say they are compatible with the TRX since the rear has a different shape gas cap as well as having a cut out for the side marker light in the rear fender. Hopefully it is something I can tweak with my dremel set.Ah, I see what you're talking about. Never seen anything like that on the TRX. Good luck with your search!
Honestly. You have found a hole in the market. Get on Alibaba.com and find a supplier and get an initial production run. You might make a lot of money.Someone needs to make wider fenders for the trx. It was close but not enough for me to spend the time tweaking. View attachment 156167View attachment 156168View attachment 156170
I was working on something similar for a no logo grille but then they showed up on Amazon. Turns out I was right about popularity, could have made about $160/ea but I was too late.
I question that...There definitely is a demand for this since most of us like to poke the tires out a bit.
With around 50k trx made i would say even 1% still is around 500 pieces. The question is whether a business sees marketing and logistics is worth the trouble after r&d.I question that...
I believe the RHO uses the same fender flares as the TRX. That would add another 15k trucks to the mix, and more importantly it’s still being built.With around 50k trx made i would say even 1% still is around 500 pieces. The question is whether a business sees marketing and logistics is worth the trouble after r&d.
If you made one for the trx it would only be for the trx since it's the only profile out of the 1500 line including the rho.
