APEX TRX
In doubt, throttle out!
Love em! My favorite aftermarket wheel on a TRX to date. Looks awesome.
Awesome wheels! Did the 0 offset require caliper grinding and did the tires rub? Thanks!Just had these 18 x9" matte bronze Fuel Shok -12 offset. (PN: D66618908445) installed ... I'll take better pics later.
Fuel 1-Piece Wheels Shok - D666 Wheels
Fuel Off-Road has been capturing the attention of off-road enthusiasts with our cutting edge designs, fitments, and technological advancements. Fuel Off-Road manufactures the most advanced off-road wheels, offering the latest in design and engineering innovations on the market.www.fueloffroad.com
I have the +1 version with no issues.The 0 offset version also cleared when I mocked it up on the hub. There's a pic of that somewhere. Didn't mount a tire on it but there's no reason it would rub if the same size wheel in both +19 and -12 don';t rub.
Ok thanks alot! I just talked to Fuel and the 18s are on 45 day back order, so I went with 20's with a positive 1 offset, they said that should fit without being to aggressive.The 0 offset version also cleared when I mocked it up on the hub. There's a pic of that somewhere. Didn't mount a tire on it but there's no reason it would rub if the same size wheel in both +19 and -12 don';t rub.
Awesome thank you both alot! Cheers!I have the +1 version with no issues.
Here's a Bighorn on 18" Rebels, in case helpful: https://5thgenrams.com/community/threads/fitment-confirmed-fuel-rebel-18x9-12-305-65-18.31604/If the 18" Fuel Shok wheel fits with -12 and 0 offsets, there's a good chance the 18" Fuel Rebel 6 wheels will fit with a -12 offset.
Wheels Fuel Rebel 22x10 Gun MetalIf the 18" Fuel Shok wheel fits with -12 and 0 offsets, there's a good chance the 18" Fuel Rebel 6 wheels will fit with a -12 offset.
Can you jog your memory about the wheel weights needed? I am seeing on Tire Rack they recommend lip mounted wheel weights for clearance. Did you have any issues with that?Just had these 18 x9" matte bronze Fuel Shok -12 offset. (PN: D66618908445) installed ... I'll take better pics later.
Do you still have it setup like this? What’s your long term review on that rim size with -12 offset? Any issues with aggressive off roading rubbing?get many rock chips with that poke? TIA!!I had already tested the offset with 1.5" spacers in my stock wheels (pic in my sig) so I knew I was happy with that stance. If a person wants to be a little less aggressive they can get them in the 0 offset which I already tested and clears the calipers.
