TRX Dimensions
Slim
Ashburnham MA
2019 Ram Limited Pearl White
I saw that the TRX has listed dimensions of 232.9L/ 88w/ 80.9 H
Would that height include the satellite fin on the top of the roof or would it be the height of the cab plus the fin? Thanks in advance
I believe that is to the top of the satellite fin. which barely fits the height of many garages I think...
Yeah that is just about where my garage door hangs when open. I got plenty for the length and width. HMMMMM
I might be stating the obvious and you've already looked into it, but there are stop that can be adjusted on the garage doors. If you still have more track left (on both sides and the center pull) you might be able to have it raise up more.... Just a thought.
My 2019 Limited is said to have a height of 77.6 from what I can pull up on the internet. I just pulled in my garage and I have 5 inches of clearance with the truck in "Normal" mode with the air suspension from the fin to my garage door.
Hopefully it looks like I might have 1.7 inches to spare if I the "Normal" mode is how they measured the Limited
So you got me thinking... as a person to who spends every week (almost, but not lately) at the airport, I called to see what the height restriction was for my reserved parking lot.... 6ft 8 inches. Doh! off by 1 inch.. ok call it 3-4 inches to be safe...
Good news is the International Parking deck as my reserved parking as well, and its 8ft 6inches so when I take the truck I'll be headed over that way I guess.
Just something to consider I guess...
Anyone know much the RamBar will add to the overall height?
From everything I have seen looks like 2 inches over the shark fin on the cab. You will have to add the height of lights you add.
Hope that height is right. My garage opening is 82.5. Have black TRX ordered but no promises on delivery date. I left the ram bar off because I knew the height would be critical.
That is smart and you can always add it later, I'm sure there will be aftermarket cheaper options
I knew I had a 7 foot door so I deducted for the weather strip and came to the 82.5. Well I decided to measure...would you believe 79.5!
if I depress the weather strip I can get 80”
Now I’m worried...y’all better get your measuring sticks out.
Lowering kit?
Ya I have a similar concern. I have a double garage bay that is 22' deep but the opening is 82.5" then I have a garage bay that is 20' deep and 95" high. I did order the Rambar so I wonder how much height that is going to add. Surely over a few inches so I guess I'm going to need to plan on either removing the Rambar to fit it in the garage I want to or shoe horning a 19' 6" truck into a 20' space. :/
Mine isn't going to fit I already know but I just purchased the land beside my house to build a detached garage. I'm going to use my 2019 sprinter van height of 114" for my minimum door height. Hopefully get started on it next year once I get the trees cleared out
Is anyone considering putting a BedRug in their TRX? Obviously, BedRug doesn’t have anything listed yet for 21 models... does anyone know if the bed size is identical to a 2020 Ram with the 5’7” bed?
Sorry about the picture quality. Saw this on the news a few mins ago and grabbed my phone to get a picture of it. Wish the TRX was parked directly next to the Raptor, but maybe gives a little bit of a height comparison though I’ll admit it’s difficult to really tell from this pic alone.
I have a 82.5” opening with door adjusted even with top jamb. My current Rebel at normal height fits in with about 2 inches to spare over satellite fin. I’m going to raise it to off road and “gently” give it a try with my wife guiding. If it will go in raised to off road TRX should fit ? I’ll let you know the outcome!
My garage height is the same, have you been able test this out yet?
Do we know for sure that the Rambar adds 2” or is it more?
If you are in an area with snow, don't ever back out without shoveling with a 7' opening. Did it at my last house and had to replace the fin on my lifted 1500. PITA. 8' doors and 22' deep should be a minimum standard on new builds.
Building a new detached garage/man cave and doing 9x16 for the door. This is where she will sleep.
