Lately I’ve seen several TRXs with transmission failures, most before 100k miles. The frequency of these type posts online seems to be picking up as these trucks age and get some miles on them. Aside from the active threads here, search “transmission” in the main Facebook group and you’ll many recent examples.
None of these owners have mentioned any maintenance done previously and since the manual doesn’t recommend any, it’s likely they were untouched.
We can’t know how many of these could have been saved but there are two things you can do to improve your chances. And all too often these solutions are presented only after you’ve already had issues and it’s too late. So consider this a friendly reminder.
Regular service. The advertised “lifetime fluid” is a self-fulfilling prophecy and should read “lifetime of the factory powertrain warranty”. Beyond that, good luck.
On mine, I did a pan drop and additional drain and fill at around 25k. Beyond that I am targeting regular 25k mile spill and fills, basically refreshing with 4-5 quarts of new fluid each time. When you get the hang of this it really doesn’t take much longer than an engine oil change.
Fluid capacity: 9.5 quarts (dry)
OEM pan/ filter assembly: 68261504AA
OEM Mopar fluid: 68218925AB
Aftermarket fluid alternatives:
Ravenol 8HP. This most closely mimics the OEM fluid in composition.
https://www.ravenolamerica.com/passenger-car-products/atf-fluid-ravenol-8hp-fluid/
Red Line D6. I am currently using this in a Jeep 8HP, great shift quality. PAO/POE blend, good oxidative stability and shear resistant.
https://www.redlineoil.com/d6-atf
Amsoil Signature ATL (blue). Popular option and great quality product.
https://www.amsoil.com/p/amsoil-signature-series-fuel-efficient-100-synthetic-automatic-transmission-fluid-atl/?
HPL ATF Green CC. Running this in my TRX with great results. Similar to the D6 in formulation but green in color instead of red, so its usage won’t be obvious to a dealer.
https://www.advlubrication.com/coll...tic-transmission-fluid?variant=41597446226113
Overall if you change it on a decent schedule it doesn’t much matter what you choose. Just changing it is the important part!
Manage temperatures. Once you have the fluid changed, you can give it (and the transmission) a longer life by keeping it cool. The stock TBV is an absolute joke with a pinhole sized outlet and a thermostat that opens too late (when it opens at all). The Mishimoto TBV is cheap, easy to install and keeps temperatures right where they should be for optimal shift quality AND transmission life.
https://www.ebay.com/itm/226725743267?
https://www.ram-trx.com/threads/mishimoto-transmission-thermostat-preliminary-review.24229/
Just some things to consider…
