Taxmantrx
How come when in tow mode the miles of towing doesn’t register? Tia
I tow often. A flatbed and a horse trailer.It does on mine with a trailer hooked up.
Actually I use an adapter with 7 to 5 pin. And flatbed 4 pin. But if I put in tow mode you think it would register miles. Must be my problem.Maybe it only works with a 7 pin connection? Though I'd imagine that a horse trailer would be 7 pin with brakes not just a flat four.
You can put it in tow mode and not have anything attached and it would then be racking up tow mileage. But when you have it connected thru a 7 pin you are most likely towing at this point. That is why i think they went with that logic.Actually I use an adapter with 7 to 5 pin. And flatbed 4 pin. But if I put in tow mode you think it would register miles. Must be my problem.
