Thinkware Dash Cam Help
Agswin
College Station, TX
2023 TRX Lunar Edition
I just purchased a 2023 Lunar Edition, and it had a Thinkware front and rear dash cam on it. I have since removed it because I could not get it to respond and the install was messy. I cannot find any sort of markings on the camera except the name in multiple areas. Is there a way to figure out what model it is? I would hate to just toss it if it was expensive and someone else could use it? I can post pictures if needed. All it says is "4k-OHD Digitial recorder" and "Thinkware dash cam"
Thinkware 4K dash cams are their expensive buggars. Typically, on the spot where it mounts to the windshield, you’ll find a label with model info.
Pictures would be good.
Attached
Thank you, much less expensive than I thought. I got the all in one FitCam to replace it. Much cleaner set up
