NEW Tazer DT Wish List
What's the pricing looking like on the new Tazer for the group buy/forum members discount once it's released?
The group buy ended at midnight this past Friday and the price will not change from $329.
Mine is working pretty good. Just a few issues.
Sometimes the front camera gets stuck on after the parking sensors activate it. I have to pull over and restart the truck to fix it.
I would be fine with just using the double tap mute feature to bring up the cameras but it doesn’t work at all for me.
I’d also really like to be able to set the front camera to a button remap. That is the one that I need to access quickly while I am out on the trail.
That and the written directions are a nightmare to decipher.
UC VERSION:FCA-MY22.S26.17-PROD
TTAZER VERSION: 18.1.8
My front cameras persist after the sensors activate them as well, but I find that going into reverse then back to drive clears the cameras. Give it a try and see if that works for you as well.
When this happens on mine switch it into park and it resets. At least for mine that’s been my work around, but knock on wood it has been more good than bad.
Same issue stuck in front camera mode, putting it into park does reset it.
Can we get an option to automatically deploy the side steps and keep them out when the ignition is shut off? I always like having the side steps out in parking lots to save cart dings and at home so if I have to go grab something the steps aren't opening and closing for no reason.
Here's a Tazer update idea.
I was in a rental car last week that used the front sensors to let you know with a very light beep that the car in front of you at the light has driven away. Keeps us distracted driver's from holding up the line.
Park cam is fixed in the upcoming update.
Did they add the front camera to be able to use with a hot key? That would be awesome for the trail.
You already can use the front cam with a hotkey. You can set it up as a widget on your home screen.
Correct. That sucks. I use full screen car play and it’s at least three touch screen presses away while on a bumpy trail. A hot key right on the steering wheel would be great.
It only takes one screen press for me (to get to the camera). You just have to set up an icon along the top of the screen.
