Shifts And Grins Fabrication 30" Light Bar Brackets
For ours we offer Amber and Clear. I have the Amber 30" light bar on mine. I can show pictures of our TRX with the Amber and some other 5th Gen Ram's with clear so you can get an idea. I have a lot more photos I can send as well. I am out of town and have spotty service so I will respond when I am able to check back in. View attachment 52605View attachment 52606
How long have you had your cubes on? Do you hear any wind noise at freeway speed? I really want some but am worried they will whistle.
I’ve had this set on for a few months. If they are pushed to the outside you will get some wind noise. I have them pushed in more and haven’t noticed wind noise with where they are currently. When I had the SS3 pods on they were pushed out further. I switched to the SS5 pods and moved them in a bit and haven’t noticed any wind noise since then.
Pushed in meaning moving the entire unit toward the center of the truck so it is in front of the A-pillar? Or do you just mean aiming the unit toward the center?
I moved them a little more towards the center line of the truck since I switched from a 3” pod to a 5” pod.
Any updates on the video? Looking to add the lightbar if the install is pretty easy.
I have not been able to get it done. I am drowning in work. I will see if I can send you enough uncut or unedited video to get you what you need. I apologize I haven’t been able to get that done.
No worries. I'm not in a rush. Just looking to talk myself into a project between Christmas and New Years.
The hardest part is tightening the light bar to the brackets because it’s tight and hard to get your hands in there. Removing the bumper is easy. The wiring is easy. Installing the brackets to the bumper is easy. There is one piece of plastic in the center that has to be cut. There is no place for the light bar to go with the plastic piece in there.
So the following bracket is good for the standard Ram 1500 and the TRX?
Yes. That is the bracket set I installed my 30” light bar on my TRX with.
I only have 1 long 18mm wrench, is that enough to remove the bumper or will I need some additional tools?
