This weekend, while driving I noticed my coolant temp fluctuating fairly quickly and repeatedly (running up to 212, then dropping to 199, then repeating within a minute). From some past threads, it looks like a bad thermostat was the issue.
Questions:
1. I ordered a new thermostat, but it did not come with a gasket for the housing. Do I need to source a new one or is it an O-ring or something on the housing side?
2. Do we have a drain on the rad that I can use to lower the coolant level before popping the housing off and dousing everything?
3. From a cursory glance, one of the bolts seems to go through the housing from the front? Will I need any special sealant?
Questions:
