Yep.@OnTheReel is this the same filter you are using?
Amazon.com: PPE - Premium High-Efficiency Oil Filter (Short) 114000740 Compatible with 2020+ GM 6.6L Duramax L5P (Replaces AC Delco PF26) : Automotive
Buy PPE - Premium High-Efficiency Oil Filter (Short) 114000740 Compatible with 2020+ GM 6.6L Duramax L5P (Replaces AC Delco PF26): Oil Filters - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
I actually never ran a 192, went from stock to a Mishimoto 180 when I got tuned. From what I’ve seen most of the 192s are made by Motorad regardless of packaging / branding. It’s probably a crap shoot. Even the OEM thermostats fail way more than they should so I wouldn’t mind taking the chance myself.So for the vast majority of us who just drive normally and are stock, would you still recommend the Redline 0w40? Or 5w40 now? I am at 30k and going to start doing my own oil changes, and have seen your previous posts about it. Not sure if that is still your oil of choice for stock motors though. Also, which 192 thermostat do you recommend? I have stayed away from those because of all the posts about them failing but it sure does run hot here in South Florida.
I always had good results on RL 0w40, and 5w40 was a slight improvement from that, even up here in the north. So in South Florida I can’t foresee any downside to using 5w40.
