Rear End Issues
Friscomail
Dallas Texas
2022 Ram Truck
No
Folks, I have a 2022 TRX with 25K miles on it. I have noticed lately that the rear end seems sloppy - sometimes when I put it in reverse or drive I get a "clunk" in the rear end. Seems like there is some play. Obviously its still under warranty but anyone else have a similar issue?
Welcome to the “Clunk Club.”
I had a rear drive shaft replaced and the clunk came back. Next they did the fancy lube job. So far no clunk, but I know it’s a matter of time before it returns.
Are you also feeling the "clunk" when you pull up to a stop light.....or a clunk when you take off from the stop light? Same clunk @04Ram2500Hemi is talking about. Its a known issue with the slip splines on the drive shaft and a bind that occurs. Its annoying, but it is not causing any damage to your truck and RAM does not have a permanent fix.
Using the word clunk is going to bring up a lot of search results / comments that are about braking at a stop light and hearing a clunk from the crankshaft and getting a forward vectoring impact.
What you are referring to sounds different and may be due to loose or out of alignment suspension components or a misaligned axle. My 23 does it too after getting t-boned. Gotta have the rear end inspected again unfortunately.
Mine does it now and then......I also have a 2007 AWD Cadillac Escalade that does it now and then so I don't sweat it.....If it kicks a drive shaft out I'll be like well it was something .
Thanks everyone. First time owning a Dodge/Ram. To answer the question from RedEyeTRX, it mostly happens when I shift into gear ....sounds like a trip to the dealer is in order! thanks everyone. Very helpful.
I believe the clunk you are referring to is different from the infamous clunk that has been the topic of most conversation on the forum.
I had the clunk when coming to a full stop or leaving a full stop. That was temporarily corrected by the dealer using a lube kit and was covered under warranty. That solution didn't last so they put in a new drive shaft also under warranty and that has solved the problem so far.
I have noticed recently that I sometimes get a clunk when first going into reverse or drive at times. This is definitely different than the first clunk issue I described. It will be going in for oil change soon and I will have the dealer take a look at it. Let us know what your dealer has to say about it. This clunk issue is the only annoyance I have had with this truck and I have been very happy with the TRX.
I’m going to have my trans fluid changed next time and see if that does anything.
justboltons.com BwoodyPerformance.com Granger Chrysler Jeep Dodge RAM OffRoadAlliance.com/ solisracinggroup.com Mark Dodge.com
