RamBar light wiring
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
2021 GMC Yukon Denali
Need a good, clean, waterproof wiring solution. There will be 4 Mopar lights mounted on my Rambar. Those 4 lights will all be powered using one of the appropriately sized aux switch in my TRX so I won’t need to add fuses, relay, etc.
My question is this. Coming from the lights I will have four hot wires and four ground wires. Those 4 hots need to connect to a larger gauge single hot coming from the aux switch as well the four grounds need to connect to a single ground wire. I’ve been scouring for a solid solution for those 4-to-1 wire connections. Something that looks clean, is reliable, and preferably waterproof so I can make the tie under the bed and run single wires up to the engine bay. Terminal strips? Some other kind of connector? Straight solder joint with shrink wrap? I’m open to suggestions. I feel like the best answer is going right over my head tonight.
TReX-RAM
TRX Junkie 💉
CA
TReX
You might find something here:
Thread 'TRX Upfitter Switches Info'
https://www.ram-trx.com/threads/trx-upfitter-switches-info.2525/
Tom488
New Jersey
I've used these many times with great success:
https://www.amazon.com/gp/product/B08F3ZM6Z9
For extra protection (and because some times the solder leaks through the outer sleeve a bit, especially if you're a little overzealous with your heat source), I heat-shrink over these connectors. Use a length of heat shrink tubing about twice as long as the connector, to ensure adequate coverage. Then protect all the wiring (and splices) with wire loom.
KingsCamo
TRX Launch Edition!!
Utah
Name
Kevin Pritchett
2021 Ram TRX Launch Edition
2017 Ford Raptor 2013 Ford Raptor 2019 Land Rover 1996 Toyota Landcruiser
I did KC lights. KC has a connecting wire that use just one instead of four. Would think it would work with Mopar lights.
I drilled into the Ram Bar and hid the wires.
DBO
TRX Noob
Missouri
21 TRX
What are the details about the lights you are using? Size, lumens/cds, mounts? I want to order some!
KingsCamo
Utah
Name
Kevin Pritchett
Used these!
Love them!!’
E
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
I’m joining 5 wires do you suggest selecting one large enough to maybe crimp two on one side and three on the other? Then heat shrink over very well?
Nice. I’ll take a look at buying a harness from them.
TxSkye
Texas and Georgia
Name
Skye
2021 TRX
Here’s my light setup. I crimp spice shrinked all the wires hidden in the Ram and connected to aux 1. Worked great.
DriftHeroX!!!
USA
The cleanest solution I've found are to use WAGO connectors and then put them in the WAGO Gel Box:
E
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
That is PERFECT! Thanks Brother!
