PSA: Go, right now, and seat all fuses and relays
Two
The actual Midwest
Too many to list
I check as much as possible once getting a vehicle home. They go from the trailer to the lift.
Okay, the TRX didn't, because it doesn't fit on the 4-post.
RobR651
TRX Addict
Boise, ID
2015 Ram 1500
I did some digging around on some other FCA forums and apparently the “not fully seated”fuses are a fairly common thing across FCA products.
lordofsmolpp
Nevada
2021 RSQ8, 2019 GS-F F 10th anniversary, 2021 TRX
Confirmed. Loose fuses and relays in both places. My truck was built in April.
Thank you for the heads up!
RR305
Hialeah
TRX
my build date was early jan! i had about 5/6 not seated and the negative terminal on my battery was completely loose not even hand tight !! I'm amazed it didn't come off going over speedbumps.
Caliche
Moderator
Staff member
Texas
2021 TRX
2018 Polaris 1000 Ranger SxS
Both of my boxes had 50% not seated. Built Feb 12. Thanks for the heads up!! Cheers.
Twisted Pair
TRX Noob
Hill Country, TX
Name
Chuck
2021 TRX
Shallow Sport X3, 2018 Harley Ultra
U.S. Air Force
I just checked mine under the hood, I would say 90% of them were unseated, some were barely installed. Thanks for the info!
JumpSquadAuto
TRX Addict
Boston, Ma
2021 Ram TRX
2020 C8 Corvette
@scottn Looks like your list just keeps growing.
Thanks everyone for the update. Will check in the morning.
Copenhagen
Michigan
There is two 7 mm fasteners holding that cover on at the very bottom. Make sure to remove them before pulling too hard on it.
About 2/3 of my engine bay fuses weren’t seated fully and about 90% of the interior fuses were loose on my truck.
Thank you the heads up!
BusaDave
DFW
Name
Dave
2021 Black TRX
2021 BMW X5 M
You know I really do like the truck BUT with the very questionable build quality and the problems I have had may let it go for a Raptor R when they come out. Going to call my Ford contact and see about getting on a list. This puts an end to the exhaust I was planning and a light bar behind the grill. I am very sad actually had high hopes for this one. :(
TyRX
Texas
21 Silver TRX
69 Camaro w/ LS swap
BusaDave
DFW
Name
Dave
2021 Black TRX
2021 BMW X5 M
Just dropped the panel on the drivers side and most were not seated completely. Glad this truck is so smooth off road otherwise some of those may have backed out sooner than later. Makes me wonder what else? Going to check the battery cables just for fun later when the rain clears out completely.
SorbSRT
SorbSRT
Colorado Springs
2021 TRX
2020 Jeep JTR LE, 2018 JEEP JLR
USCG
PSA #2: As folks have noted, the under dash fuses were just as unseated as those under the hood. After seating those under the hood, grab a 7mm socket and lower the dash kick panel and seat those loose fuses.
KnightMare
Moderator
Staff member
North Carolina
'21 Outlander XMR, '19 Sprinter 144, '19 Accord, '18 ZX-10rr, '15 Caravan, '17 Fusion, '12 Pasat CC, '11 ZX-10r, '04 Avalanche
'67 Pontiac GTO, '67 Lemans Convertible, '69 Camaro, '69 Chevelle, '70 Chevelle, '70 Chevelle
TyRX
Texas
21 Silver TRX
I only had one relay that wasn't fully seated under the hood. Either mine didn't get built on a Friday or my dealer PDI was above par.
KnightMare
Moderator
Staff member
North Carolina
RR305
Hialeah
TRX
PSA #2: As folks have noted, the under dash fuses were just as unseated as those under the hood. After seating those under the hood, grab a 7mm socket and lower the dash kick panel and seat those loose fuses. View attachment 14876
😑 great , I'll update later on tonight if mine were also loose .
