Problem with Aux Switches (recall last state)
Scottsdale, AZ
Name
Todd
2021 Ram TRX, 2021 Wrangler Rubicon
Anyone else having an issue with this? Installed some backlit led pods this wkd. Backlit feature on one aux, main beam on another. Being amber backlit I want the 'remember last state" to work so it comes on with ignition every time. For some reason it wont do that. Ill switch to another aux later today to check functionality, but in all Ram and Jeep products Ive had, its always worked when set correctly in setting menu.
Pic, just because....
fireman603
Orlando, Fl
Name
Mark
Rental - Just sold my Shelby F150 and waiting arrival of my TRX
I have the exact same issue. At the dealer now but it looks like it’s a research issue as they can’t find anything wrong
04Ram2500Hemi
Montana
2021 Ram TRX
@TheCustomJeepBuilder do you have more pics of your “ditch lights” you can post? I’m working through exterior illumination plans while I wait for my TRX to be built, and I was hoping you could post more pic and setup info on the lights of your A-Pillars.
SorbSRT
Colorado Springs
2021 TRX
2020 Jeep JTR LE, 2018 JEEP JLR
USCG
Not sure if this is your problem but if listening to your radio when you’re parked with just the run/ACC on, this is when the engine isn’t running, the last state is “off” for your aux switches.
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
2021 GMC Yukon Denali
No but thank God for those that have served!
Did you ever resolve this issue?
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
Did you ever resolve the issue of the aux switches not recalling last state?
fireman603
Orlando, Fl
Name
Mark
I haven't. I have appointment on the 13th of this month with the dealer to continue to work on the start case they have opened. I hope to find an answer then.
Will keep this post updated
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
The service department at my dealer believes it is a faulty BCM. They ordered it this week, it arrived today, and it is being replaced next week. Will advise if it resolves the problem. Cannot say I am hopeful because I think its more of a guess of what to try first.
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
Any luck on resolution of this aux switch issue for you with the service dept?
fireman603
Orlando, Fl
Name
Mark
They have decided to replace my body control module to see if it fixes the issue. It gets installed this Friday and I will let you know the result.
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
same here and installed Friday as well.
fireman603
Orlando, Fl
Name
Mark
BCM is installed and did not fix the aux switch issue. Another star case is opened, and they are trying to find someone who actually knows how they operate, but aren’t having any luck. It has been escalated twice now since I have been sitting here, going on 3 hours now.
Elarson6772
Saginaw, MI
Name
Eric Larson
2021 Ram TRX
Same here. BCM was replaced this morning and was a no go as well.
Do you have a Starcase# and dealeship name/location? Maybe if they need to coordinate and get two service departments pressuring them it might help.
Mine is Shafer & Bierlein in Frakenmuth, MI
fireman603
Orlando, Fl
Name
Mark
They are in touch with the audio group now, not sure why, but I am at Daytona CDJR in Daytona, FL. My star case is 101949188. Hope it helps us.
