Picked up truck with New tires/wheels
Ziegsraiders
Nashville
Name
Ryan
NA
Picking up my truck. I Put 37s—Toyo MT1350s–With 18” black rhinos (+15 offset). No rubbing so far.
APEX TRX
In doubt, throttle out!
IL
2021 TRX
2018 Raptor, 2019 Hellcat Redeye Widebody, 2018 ZL1 1LE, 1996 Bronco, 2015 Explorer Sport
Looks awesome and congrats!
RaptorTillNow
PNW
17 RAPTOR, 802a, BL, CF, Pano!
06 E55 AMG
Looks good...I like silver! Any rubbing?
Caliche
Moderator
Staff member
Texas
2021 TRX
2018 Polaris 1000 Ranger SxS
Congratulations the silver with those bad ass wheels looks awesome. Hope you like it as much as all of us.... Enjoy!
JAG91
Tulsa, Ok.
17 Powerwagon, 18 Trackhawk(SOLD), 02 Camaro SS
Nice, something about the silver makes the tires look even bigger.
04Ram2500Hemi
Montana
2020 Ford Raptor
That looks great!
I’m assuming you had the factory black wheels from the start?
Ziegsraiders
Ziegsraiders
Nashville
Name
Ryan
NA
That looks great!
I had my buddy, who runs the dealership, put the aftermarket wheels and tires on at the dealer before I picked up the truck. I decided to go with more tire instead of more wheel—which looks great.
CustomPerformance
Houston, TX
Looks awesome! Is that the Black Rhion Raid? Looking at the BR website it looks like it's an 18x9.5 with +12 offset. If that's the case then it's good to know they fit with no rubbing! That means up to +12mm out from stock works without rubbing.
Edit: See OPs post below. These do rub.
T-REX 797
Wisconsin
2010 Dodge 1500
Not that MPG is anything to brag about but how much worse is it with 37 vs. 35
lootawi
TRX Noob
Dubai
Name
Sultan A Lootah
RAM TRX
Looks amazing, i assume there was a brake caliper grinding ? or all was smooth ? does the allignment stick on wheel weights clear the caliper ?
BusaDave
DFW
Name
Dave
2021 Black TRX
2021 BMW X5 M
Oh they will rub when the wheels are turned and the suspension goes far enough into travel. Just hope not too much damage is done.
Ziegsraiders
Ziegsraiders
Nashville
Name
Ryan
NA
you're right, they rub slightly at full turn--nothing major and doesn't happen often. However, I will put on stock wheels and rims on if I go off roading.
