Peasant vs Beadlock Wheels
Stock vs Beadlock Wheels
  • Total voters
    75
I had the stock black ones and really liked them. Beadlocks look so much better in person vs pics. The black beadlocks look awesome.
I personally would get aftermarket though so none of the two
I ordered my truck with beadlock capable wheels but bought some of the standard wheels off a forum member. I'm running the standard wheels now and actually like the look of them better. It's all personal preference honestly, both look good. I'm keeping the beadlocks in case I ever change my mind LOL. I weighed them both when switching out tires and the beadlocks are 13 lbs a piece heavier. That's quite a difference, basically the same difference in weight as a 37" tire vs a 35".
Well, not really. 13lbs of wheel weight is the equivalent of ~6lbs of tire weight.
Consider this…my street tires are 32” (so the effective gear ratio with them is ~3.84) AND they weigh 16lbs less than the stock black non-beadlock combo, AND they hook better than the ATs AND probably have lower rolling resistance. But all those changes were only good for shaving 2 tenths off the 0-60 time (Dragy verified).
I guess what I’m saying is simply adding 13lbs while leaving the tire and everything else the same isn’t going to be noticeable. It takes more drastic changes…
43 lbs is still heavy for an 18" wheel, especially considering they aren't even a true beadlock unless get the parts to convert them.
So more weight, less MPG? C'mon! I'm already at 9.3 MPG and barely touch the gas pedal :LOL:
Both wheel choices are “stock” as they come from the factory. The proper way to ask is “Bead lock, or Peasant wheels?”
People know what I mean. But okay, let's update it. ;)
Go with the beadlocks. They definitely look better. Don't worry about the extra weight. Truck is already the slowest color so may as well look good while putting along 🐢 😎 🙊
I have to vote black Beadlock wheels myself.
Standard Wheels
Black Beadlock Wheels
I bet you have a blue one. 😆
I have a set of 4 black beadlock wheels with 8,500 miles on them that came off my '23 Lunar Edition if anyone is looking to buy a set. $2k not including shipping. I'm in SoCal. DM if interested before I list them on the marketplace.
I was lucky a did a straight across trade for my 20" Fuel rebel 6's with 35" ko2's, Got a brand new set from a local guy. Met up at Discount Tire and split the swap fee $50 bucks I believe. They were on the truck when i bought it, wasnt a fan.
How much is the shipping to Miami?
View attachment 129743Mine came from the factory with one of each wheel so you may want to give that look a try! Only half of the extra weight. ;)
I can’t believe that! Are you joking, right? What that F! This tells you that QC in factory is like none. Wow! What set did you asked at the end?
