So a few of the exclusions that have burned some people (who didn't read the fine print):
18. Battery and cables; any battery for a component (doesn't affect the TRX, but anyone who has problems with the eTorque battery); spark plugs and wires; lights (bulb, sealed beams, lenses); suspension alignment; wheel balancing; wiper blades; catalytic converter (take note), particulate filter and any other exhaust system components; heat shields and exhaust hangers; throttle body cleaning; evaporator deodorizing; carbon cleaning; replacing outdated, lost, stolen, or damaged navigation DVDs;
19. Exterior - tires; trim; name plates; appliques; body sheet metal; glass; plastic lenses; paint; bright metal; bumpers; side-view mirrors (glass/ housing); wheel covers; steel wheels; aluminum wheels; rusted or frozen rims; weather strips; rust; water leaks (if you suffer from the common rear window leak, shark fin leak, etc., then you're on your own); restricted drain tubes; wind noises; all outer body panels; spoilers; plastic and fiberglass body parts; vinyl tops; convertible top fabric; repairs or damage caused by environmental factors such as acid rain, tree sap, salt or ocean spray;
21. Interior - trim; carpet; upholstery; dash pad (delaminating dash is your problem); door and window handles; knobs; buttons; moldings; arm rests and head liner; cargo cover; cosmetic appearance; torn/worn/soiled;
