Featured
- #1
Finally had a chance to install one of the two side mirror ditch lights. No I haven’t wired them yet because I’m waiting to do the passenger side first. Install was pretty straightforward with the following hiccups.:
Step 4 requires removal of 4 torx screws (not 3). Almost destroyed everything prying it apart with 1 bolt still secured lol.
Also, steps 11 and 12 are not necessary because there is not enough slack per below.
RE Steps 14 & 15- there is almost no slack in the factory wire loom to feed a wire through like they say. Youll need a good feeder wire (e.g., semi-rigid 10ga) and a pipe spring puller or wire hanger to grab the wire once u feed it through (see pic) There is a 90 degree turn upwards that’s impossible to make without a wire hanger type device. A little dielectric grease on the feeder wire does wonders.
One other concern that I was kind of bummed about is b/c of my mild OCD - there is no good way to feed the wire from the door into the engine bay without being visible like last pic below. I tried to find a clean way to snake it through the door and through the factory rubber wire hose, but the door is completely solid all around the wire hole going to the side mirror. It is what it is.
