ORACLE Lighting at SEMA 2025 — Booth #57147
Oracle Lighting
New Orleans, LA
TRX
SEMA week is here, and we’re beyond stoked to be back in Vegas! If you’re hitting the show this year, swing by the Oracle Lighting booth (#57147) in the Trucks, SUVs & Off-Road section — we’ve got a ton of new gear to show off. From next-gen off-road lighting to RGB illuminated accessories, you’ll see what’s coming next for 2025 and beyond. We’ll be running live demos, showing new products up close, and hanging out to talk builds, installs, and lighting setups.
📍 Booth #57147
📅 SEMA 2025 — Las Vegas Convention Center
If you’re attending, drop a comment below and let us know — we’d love to meet some of you in person!
👉 Follow along for sneak peeks and updates: oraclelights.com
Now that we’ve settled into the show, I wanted to take a minute to highlight a few of the products at the Oracle Lighting booth that are turning heads this week — including some brand-new launches and lesser-known gear you might’ve missed in the first post.
Vega 7 Series Offroad Pod Lights
Meet the Vega 7, our newest compact off-road light built to outshine and outlast anything in its price class. Designed from the ground up using high-quality OSRAM LED chips and IP69K-rated housings, these pods crank out serious light output and durability at a lower price point than most comparable setups.
  • Active Thermal Management: Integrated fan keeps temps optimal for sustained, high-load conditions.
  • Angled Lens + Symmetrical Beam: Mount right-side-up or inverted — no change in beam angle.
  • Tool-less Lens Covers: Snap-on Amber/Yellow covers or blackout covers for street compliance.
  • Built to Outshine, Priced to Win.
Fun fact: the name Vega comes from the brightest star in the northern sky... fitting, right?
15W LASER Fog Light Modules
Forget "bright for a fog light"... this thing is insane. Each module features a 15-watt laser diode that throws a hyper-focused beam over 3,000 feet for long-distance off-road visibility.
  • Full leveling built into each emitter
  • Polycarbonate lenses and aluminum heat-sink fins
  • Tactical skeletonized mounts with laser-etched bezels
  • Designed strictly for off-road use — not street legal
These are made for people who like to drive fast where there aren’t any streetlights.
TRIGGER 4-Plus & 6-Shooter Controllers
Because wiring shouldn’t require an engineering degree. Our Trigger systems make auxiliary light control stupid easy:
  • Bluetooth and smartphone compatible
  • Clean install (no need to cut into your dash or firewall)
  • Pre-wired harnesses + simple setup
  • Optional handheld RF remote for trail use
Perfect for anyone adding multiple light zones — roof bars, ditch pods, rock lights, you name it.
If you’re at the show, come check them out in person at the Oracle Lighting booth in West Hall — and if not, feel free to drop questions here. Always happy to talk lighting!
