It would be interesting to tear a few apart... but wouldn't Bilstein have already spent a fortune to log all this data you are speaking of? Seems like a whole lot of work to discover territory that is already covered. If that's your hobby, I certainly understand that.
I understand and can appreciate the aftermarket has great options for purpose-built off road shock packages. The stock Bilsteins were created for the truck, and all of the demands Stelantis had on making them "do all things".... when you design something with this expectation, you design something that is not particularly awesome at any given task. It's a win if the design is mediocre at ALL the tasks. I think Bilstein hit that mark on our shock package.
Maybe it's new to me and that is why I like it... but I really dig the push-button ride changes. That may get old once I settle into the "mode" that I decide I'll use the most. Then I might look at options that match that performance level in the aftermarket.
I hear you.
I’ve consulted (and deeper) with a few shock and suspension companies over the last… (man I’m getting old).
Including being mentored by the guy behind ‘s zr2 suspension and shock project. At the end of the day it’s still price point and 36k miles.
I was a big fan of Bilsteins original Blackhawk program, billet bypass bodies of yuminess.
I do feel that the oem shocks have great potential but the computer algorithms suck and for anyone not on a dedicated short course, they are unable to show their full potential. And at the end of the day, the oil will break down.
Gen 1 raptors had initial build intervals of 15k miles I believe. And those shocks had a lot less weight, a lot more oil etc
I’m trying to remember what the gen2 interval was but I’m out and about.
Bilstein and SRT were planning on releasing a larger body shock for the trx. Bolt in to work with the factory computer. I never asked directly if the factory algorithm would be changed but from discussions last fall, I think that was the plan.
Stellantis points the finger at bilstein and bilstein custom shop points the finger at ram as to why the project was cancelled.
I think they looked at Kings sad trx shock sales and didn’t think anyone would buy the larger shocks for their trx. Sadly that project is dead.
That’s why I looked into modifying the oem shocks, which wasn’t worth it. And then having shocks designed for the trx.
I run temp strips on all my shocks on all my vehicles to compare seal head heat, port heat, resie heat, blah blah blah blah to collect data.
There are gains to be made.
Sadly, just with out the push buttons.
I had an idea about 3d metal printing and adding the oem electronic valves to aftermarket shocks. But we would be back in the $10k per set of 4 territory.
Not sure how many people would want to spend that when the gains are not that much over a proper shock
