New ZAutomotive Parts Available!
Nick797
TRX Addict
Bensalem PA
2022 Ram 2500
16 Charger Hellcat, 2014 LS Swapped BRZ
Zauto NoLimitz
No Limitz DT is a breakthrough design to allow full output and security without any permanent modifications
  • Disables factory speed limiter (stay within limits of your tire rating)
  • Disables torque management system/traction control
  • Disables MDS system on MDS equipped motors
  • Completely blocks access to the RF Hub so new keys cannot be programmed
  • Speed limiter/MDS/Torque Management functions can be turned on and off at any time
  • Simple plug and play installation
  • Silently overrides speed limiters and torque management
  • No permanent modifications
  • Nothing in the vehicle gets reprogrammed
  • Cannot be detected by dealer tools
Finally, a way to override the speed limiter without unlocking the PCM and voiding the warranty! This little device leaves the PCM alone, so no warranty issues, no dreaded P1400 code.
Also prevents the most common method of auto theft on Stellantis vehicles, which is key programming.
________________________________________________________________________________________________________________________
Zauto ParkSense Fix
Did you install larger tires on your Ram DT, and now ParkSense no longer works? This simple plug-and-play device will get your ParkSense working again, regardless of tire size.
  • Simple, 2-minute, no tools, plug-and-play installation
  • Silently gets ParkSense to work as if the factory tires were still installed.
  • No permanent modifications, cannot be detected by dealer tools
Can I finally program my Tazer with my computer? Are the bugs fixed where it locks my from camera on? What about when it activates trail turn all on its own?
These are new devices, not the Tazer it self.
Zauto NoLimitz
Zauto ParkSense Fix
Just got my No Limitz DT this past weekend, hopefully have it installed this week. Glad Tazer / Joe figured out how to block access to the RF hub and yet FCA couldn't do that.
Zauto NoLimitz
Zauto ParkSense Fix
So the "no limitz" isn't the normal tazer? I don't care for the other features of the tazer and am old it causes issues potentially with IGLA. so if its different, I'm very interested. does it reset key counts or anything that could potentially tip off a dealer if they dug far enough? also, can you kill traction control with it? or just torque management
Does this work with the Tazer pin? Meaning they won't conflict with each other?
Given that the install location is not that obscure, can it just be disconnected to bypass? Not trying to give would be thieves who scour the forum info, but you have to imagine it's a possibility.
It is not, its a separate device all together. It can be removed just as easily as installed if a dealer has an issue with it, but unless they are trying to program a key or do something with the RF-Hub they should not have any problems.
Install (Instructions)
Didn't see your edit, but yes traction control can be disabled.
Reactions: FP3
Is the Zauto Parksense Fix a separate device JUST for people with larger tires?
Correct this is for the guys who previously ran into the issue using the Tazer to update the tire size & lost the park sense capabilities
This i am not 100 percent sure on at this minute, I would THINK so. But I don't want to steer you in the wrong direction as far as conflicting eachother..I would think so long as you aren't trying to use a feature that conflicts with a feature on the other device they would play well together. I will reach out on that.
Anything can be bypassed in that sense, In my head its all about just doing anything you can to slow them down or throw them off. The install location is certainly a little more involved then the TaZer It self.
ok, so this shouldn't interfere with my igla stuff then? I know I'm asking twice. I just don't want to order it and not be able to use it or my truck. haha
Just responded to your PM!
Not wanting to hijack the post but as with all z auto stuff I would use at your own risk. It plugs into the can bus, same one as the IGLA and having both blocking a pin from rf hub probably won’t end well but… won’t know until you try it I guess 🤷‍♂️.
That's what I wasn't sure on how IGLA installs as it seems its kept a secret(for a reason) Lol. I mentioned if it uses the same locations then it may interfere with each other.
So this is in addition to tazer dt?....you can have both running at the same time?
It doesn’t use the same “location” per say but uses the same can network that the z auto does except z auto can be unplugged (obviously). It might (more than likely) cause a can clash conflict kind of like the amp power steps do on some.
Following, interested in this.
How does it connect. Have amp steps and tazer already. So it has to connect another way?
