New wheel lug nuts, blacked out...
cortc
Miami
2020 RAM 1500 Limited EcoDiesel
Installed these to get rid of the chrome factory ones.
You will need a factory bugle acorn, a standard acorn and even the bugle acorn isn’t enough. Looking at the picture posted above, it almost looks like we are seeing a portion of the rim which factory lugs were previously covered.
These are a perfect fit, they fill the complete seat and have the same contact as the factory lug nuts... The silver metal you see is the collar built into these that keep them from gouging aluminum wheels.
The factory lug nuts are just wider past the end of the cone seat. The lock and spline drive sockets are both 22mm so the factory lug g wrench fits and works perfectly as well in case you need to change a wheel on the side of the road.
Perfect, thanks for confirming! Only four lugs come in a set. So you are buying one set of the locking and five sets of the splines?
Lug nut torque specs are: 120-130 FtLbs,I set all mine to 120...
I bought these a few months ago. Since, I've decided to go aftermarket wheels so they won't work now. Anybody interested in buying them? They look exactly like the factory nuts, but black. Gorilla 66148BDX is the part number. Quantity of 24. $100 shipped to your door anywhere in the lower 48 states.
Do they make a 6-lug box kit for these size? I found the
65610BK but they are 1.938 overall length and the ones in the pic above are 1.648. I'm sure its not a big deal as long as the lugs have enough threads for a good bite, and they don't stick out past the rim face too much.​
Still got these?
