ace32x
- Joined
- Feb 15, 2021
- Messages
- 162
- Gallery
- 82
- Reaction score
- 234
- Location
- Puyallup WA
- Current Ride
- 4500 whp Promod c6 Z06 vette
- Current Ride #2
- 2015 3500 Compound Built Duramax 1100 whp
Got around to gathering up parts now that the new whipple blowers are more readily available and doing round 2 of a build on my TRX.
Old build was one of the first trucks to crack into the 10s on stock 35's back in the summer of 21. combo back then was stock ported kong blower and snout, 108 tb, 5" intake to stock air box i fabbed up myself, id1300cc injectors e85, 2.5 upper and arh longtubes and no cats. went 10.90 @ 126 on the stock wheel tire combo.
New build consists of a Kong Ported 3.0 Whipple and Snout, 120 Kong TB, Fore intank tripple pump combo for fueling (not a fan of boost a bump solutions), Meesh tuned stage 1 cam, frankenstein stage 1 cylinder heads (CNC port, Springs, Stock valves as there is piston to valve clearance concerns going to larger valve on the stock pistons) S&B intake that we are going to modify the elbow to the Kong TB to 5". And Pinning the crank this time around with the bigger whipple unit on there.
going to be pushing the stock bottom end pretty hard with this combo on e85 to try and hit the goal of 9.9 on the stock 35's so we will see how long it holds up, in the meantime going to start gathering stuff together to do a short block on the side.
Here is some current pictures of the parts rolling in, build will start probably end of February
