NCTRX Build In progress
nctrx
nctrx
Raleigh
2021 TRX ≈
2021 Kawasaki Z H2 SE
Army
I like it …it’s not enough though. Was pretty easy to get installed, about 110 increase to the wheels. Still drives like an everyday er
MagaTRX
West Virginia
1c6srfu98mn906116
That’s what I was thinking but I had my fingers crossed it was without one more zero
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
One more zero or replace the 0s with a K
MagaTRX
West Virginia
1c6srfu98mn906116
How did the inter chillers work out, I’m dropping mine off at velocity Monday
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
still there waiting on awe to fix a problem. I’ll tell you though velocity’work specifically with the ac runs to and from the chiller looks factory. They had lines made looks freaking phenomenal. If you go on Monday have Brandon show you. I am hoping either the rest of the exhaust shows up or they will put the stock back on and dyno. What are you getting done
MagaTRX
West Virginia
1c6srfu98mn906116
Did you get the ripper tune 800 kit, I was just getting that lower pulley put on it to get a couple more pounds of boost but I may do more now that I’m thinking about it
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
Got the 800 kit upper and lower, 1k injectors and some otter stuff. The incognito is the base and you can add to it later
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
Can’t remember had other stuff done as well
MagaTRX
West Virginia
1c6srfu98mn906116
Does it make the truck feel a lot lighter I had it raptor change the turbos and everything else out on it and it seemed like it go a lot more nimble
MagaTRX
West Virginia
1c6srfu98mn906116
I had to lower incognito pulley put on Tuesday it brought me up from 11 psi boost to 14 psi boost I’m gonna go ahead and do the upper and Fuel injectors
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
👍 also last minute adjustments changing the 3.09 pulley to a 2.85 to bring the boost to 16psi truck is on the dyno just going to swap out the pulley. Should have some #s in the afternoon
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
So if you want my 3.09 you can have it. You would still need the hub, pulley drive system, I’ll catch and injectors tune and belt to match that package but may save you a couple Hundo.
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
Does it make the truck feel a lot lighter I had it raptor change the turbos and everything else out on it and it seemed like it go a lot more nimbleL
Drives like a factory truck with soem extra excitement would not say ‘lighter’ per se
nctrx
nctrx
Raleigh
2021 TRX ≈
Army
Hey nctrx how are you liking the 800 package? Did you add the ported snout and throttle body and retune yet? If so what were the performance gains? I’m in CA and have plenty of E85 by me so thinking of going the 900 route w/ ported snout and throttle body.
I personally think it is a great upgrade. However my addiction has made me change and add some more things 🤪🦖 in hindsite a different upper pulley at a minimum
