Trunty
Alrighty, just switched over to 37’s and wanted to share. Reality is I was pretty surprised by the lack of information available from folks that had already done similar. Ultimately I decided I was going with 37’s, but wanted to keep it as light as possible. Also, my suspension is currently stock, and while I plan to add JUST the Rogue top plate, I have not done that yet.
Before
Stock non-beadlock weighed in at 94.12lb (3500 miles)
Weld Ledge 6 (W108) 20x9 +0 with 37x12.50r20 BFG KO2 weighed in at 101.13lb, resulting in a rolling assembly increase of 7.01lb.
Finished product
Performance impact - While not terribly scientific, mostly because I was excited to get the tires on and I didn’t want to do too many launches with my truck. On an old sloped country road I logged one run each. Again, not scientific or definitive, but should give an idea.
With stock non-beadlock setup. 0-60 at 3.98s, 1/8 mile 7.88s @89.63
With 37’s setup. 0-60 at 4.22, 1/8 mile 8s @88.97
Overall I am very happy with this setup. Happy to answer any questions that I may have omitted!
Before
Finished product
- TPMS - I went with 68293199AA-AB purchased from eBay (https://www.ebay.com/itm/394345375962). I didn’t have to do anything special to associate/activate them, just installed them prior to taking to the tire shop and slapped them on.
- Tire size - Used the Tazer to update tire size to 36.7” and confirmed with my Dragy that put it dead one. The front and rear parking sensors immediately disabled, as expected. I have an experiment I am going to try which may address this, but didn’t have time tonight.
- Hubcentric - The weld wheels came with the proper spacers, but they were plastic. I originally was not sure if the wheels would include them so I had already purchased aluminum ones from amazon 106mm to 77.8mm (https://a.co/d/8Hlb956) They went on PERFECTLY snug and gave me a little peace of mind knowing they were dead center.
- Suspension - Stock and no rubbing, except for a tiny bit when off camber. It’s currently too close to keep it this way, but not bad enough to where I’m in a rush. Will add the Rogue top spacer as originally planned and I think it will be perfect.
- Ride quality - Feels a little smoother. I do not actually perceive any performance degradation
- Noise - I didn’t find the OEM tires to be noisy, and these are just as quiet
