MODZ
DaveG
Barnegat nj
19 rebel—TRX on the way
any info on the timing for aftermarket parts.. obviously the hellcat motor so things shouldn’t be that much different from other parts.. ?
I expect parts from other Hellcats and 1500/Rebels will work once some shops gets hold of these to confirm.
I'm interested when people start adding HP with pulley, tune, or even blower upgrades...
What would you be looking for modifications wise? Motor stuff will be quick. Pulleys, intakes, exhaust, etc will likely be out within a week or two of initial deliveries. Suspension stuff might take a bit more time but someone will have a spring perch pretty quick to level the front off. The rest will take time.
Performance parts and upgrades will likely be out (or are already out for the current hellcat platform that will fit) long before someone finally cracks the stock PCM, sometimes its quick and sometimes it takes a year or more (the c8 corvette has been on the streets for over 6 months and the PCM still hasn't been unlocked) and without an unlocked PCM and a tune performance parts will add very little actual increased performance and in some cases can actually cause damage...
