Left turn signal out message but it is still working…
I have a 2019 and this just started. Anyone have success fixing this?
From my knowledge, the only “fix” is to R&R the headlight assembly. Or the oracle LED strip. But that’s pretty involved. You have to bake and take apart the headlight.
Sometimes it’ll get a hiccup and do that at the plant and if you leave the blinker on for a bit it should reset itself. Not always 100% but 99
Hi all my 2022 just did the same thing (front driver blinker) but mine only did it after the recent Uconnect update (July 24th evening) But I also have the taser dt module in there for amber DRL’s. Now it’s stuck off and did multiple reboots and had dealer clear codes to reset and still nothing. Is it the ballast maybe on the assembly that went bad ?
You guys use your turn signals? Have you checked your blinker fluid level?
Mine did the same thing after the update in October. The dealer didn’t want to deal with me because the trucks out of warranty .. All I can think is the driver for the LED got fried on the reboot. Maybe it was given too much voltage. Either way, it’s been almost a year now and the turn signal is still out.
Damn almost a year? That’s rough. Yea I found the ballast on the back went bad, very annoying but it is what it is. They can’t get the part for 3 months the dealer said so I found a front driver assembly from a totaled TRX in really good condition almost new with some minor scratches and threw that it for now. Brought back the bad assembly to the dealer to let it sit till it gets fixed. And then sell it or keep for a spare lol
Same problem here, but not sure if turn signal reset is the same as an actual led fault on the front headlight.
