Kumho Road Venture AT52's 37/12.50R20 like new set of 4
Mscofield4
Las Vegas
22 Granite TRX
1499 Set of four like new Kumho Road Venture AT52's in 37/12.50R20. Only about 1000 highway miles on these. No off-roading. Still have nipples. Unmounted and ready to go. GREAT tires. Very smooth and quiet, especially for A/T's. Real world weight is 76 pounds each so they are also very light weight for their category. Just a bit too big for my taste. Going back down to 35's. Can be combined with a new set of Fuel Cycle or Black Rhino Rapid wheels in 20x9 6x139.7 for an additional $1499. Located in the mountains edge area of Las Vegas near Blue Diamond and El Capitan. I can drop off within the Vegas valley if need be.
Service Description: 126R
Load Range: E
Max. Load: 3,750 lbs
Max. Inflation Pressure: 65 psi
Tread Depth: 16/32"
Tire Weight: 76 lbs
Rim Width Range: 8.5-11"
Meas. Rim Width: 10"
Sect. Width: 12.5"
Tread Width: 10.2"
Overall Diam.: 36.5"
The Road Venture AT52 is Kumho's On-Road All-Terrain tire developed for drivers of Jeeps, SUVs and light trucks looking for rugged off-road performance, along with confident handling, comfort and all-season traction for the daily drive. Engineered to take command of rugged terrain along with surefooted handling in inclement weather, the Road Venture AT52 features wintertime traction sufficient to earn the tire industry's severe snow service rating and three-peak mountain snowflake (3PMSF) symbol.A durable, cut-and-chip resistant tread compound is molded into a symmetric pattern engineered to balance off-road capabilities with on-road comfort and even wear characteristics. The compound's optimized polymer blend and complex structure carbon black enhances wear while helping improve dry and wet road traction for predictable handling on the pavement. A high-void pattern provides the necessary biting edges for off-road traction while its five-pitch block variation helps minimize road noise. Extreme Side-Biters help increase grip in loose, rutted terrain while also providing added puncture protection in the upper sidewall area. Robust shoulder block geometry features saw-tooth like edges for improved loose surface grip which work in conjunction with multi-angle, high-density sipes for light snow traction that meets the tire industry's severe snow service requirements.Internal construction of the Road Venture AT52 utilizes a two-ply reinforced casing built to combine durability and ride comfort, while twin, high-tensile steel belts offer a sturdy foundation that help distribute the tire's load across its footprint. The enhanced under tread gauge is designed to increase comfort and puncture resistance with a single nylon cap ply helping maintain high-speed stability.
Some additional photos
  • uuid=72BC5847-C875-466C-85A2-A07B095D6629&library=1&type=1&mode=2&loc=true&cap=true.jpeg
  • uuid=9B4629CF-2315-4CC8-8C22-1D3ED97B4C6B&library=1&type=1&mode=2&loc=true&cap=true.jpeg
  • uuid=A8E1BEE8-2534-4559-B459-E1626301C9B6&library=1&type=1&mode=2&loc=true&cap=true.jpeg
  • uuid=D1647988-863D-4F5D-9A10-EDCE460C04C3&library=1&type=1&mode=2&loc=true&cap=true.jpeg
Great tire. HAve these on my 18 Sequoia 35" and 04 Gx470 33". Was gonna do it for TRX but got a deal on some AT3W's.
