NEW Introducing the Bomiz Valved Ram TRX Exhaust System. Pre-Order Now!
Bomiz
Orange County, CA
570S, F12, E92 M3, 22' TRX
Introducing the most versatile exhaust system on the market for the Ram TRX
  • 3" Full T-304 Stainless Steel
  • Zero Drone
  • Signature H Pipe for Tone
  • Bolts to OEM/Aftermarket Downpipes
  • No Cutting Required
  • No Check Engine Light
  • 5" Angle Cut Exhaust Tips
  • Tig Welded with Precision Fitment
  • Open/Close Valves Rapidly
  • Signature Bomiz Muffler
  • Straight Through Free Flowing Design
We wanted to build the best exhaust on the market for the TRX, and that's exactly what we accomplished. It brings out the best and glorious sounds of the 6.2L Supercharged V8 while minimizing any rasp and having zero drone.
But wait, what makes ours so versatile? We designed our system with our Rapid Electronic Valves. Be able to go from your screaming monster to a tamed house pet that won't wake up any neighbors.
The valves closed is QUIETER THAN STOCK. Perfect for people that leave in the mornings, sneak out of the house, or don't want to catch attention on the street! With the valves open we strived to make one of the best and most aggressive tones on the market.
Tip Options
  • Polished Chrome
  • Black Cerakoted
Pre-Order
We had a tough time deciding on a price that was best for the community and also worked for us. The owner of Bomiz ordered a TRX from a dealer on the forums and initially didn't think the car needed an exhaust system. Little did we know there was a hole in the market because there were no valved systems available at a decent price... so it was up to us to make it happen.
We are going into production and want to make sure we build systems appropriately and give back to the community that has treated us so well.
There is a massive pre-order discount for anyone that orders immediately, it won't last long! We also had Black Friday in mind with our pricing.
ETA - Late Dec - Early Jan
Order Here
Will the spare tire still fit under there?
Yes it will, it's just much easier to remove the stock exhaust system taking off the spare tire guard. Plus I have aftermarket wheels and don't need the spare tire
Can the valves be wired to one of the aux switches instead of using a remote?
We're thinking of a way to do this. Right now all the control box needs is power and it includes a small key fob. This is the best way to control it IMO
With the spare tire guard removed, can you fit a 37?
I really want an exhaust that opens/closes automatically. I just want it to open (fast) when I’m getting on it and then immediately go back to normal when I’m cruising. My corvettes did this extremely well.
Pretty cool.
This would be a nice option, we're just not capable of it currently.
I definitely like the quiet option over the QTP cut outs. I will check back after deliberating some more. Overall it looks like a solid system.
Sounds solid! Can you give us some clips of highway cruising with valves open & closed around 1500-1800rpm, 2000, 2500 rpms?
Also , what is the total weight of the system?
Finally, I'm probably on board if we can wire up to an aux switch as opposed to a remote. If you can guarantee that ability, then I might be down for pre-order!
In my opinion, it‘s a big miss that you must run a fob to adjust the valves. Integration with Homelink, an AUX switch, or something else already in the cab presents a significantly better user experience. Value seems good, though, and the brand seems to build quality kit. Great to have choices!
I don't suppose there's a "partially open" option, is there? From what I see above, it's either "quieter than stock" or "loud as shit". I like the current volume that I have for everyday use. Would like a quiet option (as I sneak out of my neighborhood at 5:30am), and would like the loud-as-shit option too (for fun). But would like an everyday option that is similar to stock (or maybe a hair louder).
If the fob is like the QTP fob you are able to connect to homelink buttons.
Definitely interested if it can be controlled by HomeLink or Aux switch.
justboltons.com BwoodyPerformance.com Granger Chrysler Jeep Dodge RAM StopwatchUSA.com OffRoadAlliance.com/ solisracinggroup.com Mark Dodge.com
