AZDinoPwr
TRX Maniac
For those running 108mm or similar larger throttle bodies, what intakes have you settled on? I have the S&B stretched a little so it’s a better fit with the 108mm TB but that still leaves the intake elbow as the restriction point (about 100mm). I believe @10mpg fabbed an adapter pipe to go from S&B to 108mm but wondering if there are other options that still utilize the hood scoop that I’m not thinking of. Would like to avoid all the 5” hot air intakes.
Thanks all!
Thanks all!
