HOT! IN STOCK EBC Rotors & Brake Pads for RAM TRX (2021-2024)
Johnny@JustBoltOns
TRX Maniac
Central Florida
2005 Mustang V8 Swapped / Insane Long Mod List.
EBC Rotors & Brake Pads for the Ram TRX (2021-2024)
USR Slotted Style:
The USR or Ultimax slotted rotor range are our premium silent premium street range designed for fast street use and is made using the highest quality G3000 grey iron rotor blanks.
BSD Style (Blade Sports Discs):
BSD (Blade Sports Discs) are made from a unique material known as “discalloy” for front and rear fitments. The blade slot design is specially crafted to remove hot gases in an efficient way to help keep brake pads cooler and flatter. The multiple slots overlap to reduce the brake wind sound.
GD Sport:
We also have the full array EBC Brake Pads from Ultimax, Bluestuff, Greenstuff, Yellowstuff, etc available to pair with them. (some are below)
I just did the yellowstuff pads and the GD rotors on my older 2003 duramax, have to say it did help a LOT over the stock setup ( did the upgrade 2011 hydraboost too) I have the green stuff on other trucks, for the TRX ummm probably the green, but the yellow does bite better IMHO
We definitely appreciate that feedback. EBC makes some good stuff.
I know not everyone wants to swap Calipers so it was worth sharing these on here. We do sell a good bit of EBC kits for other vehicles but also try to stock Alcon / Wilwood kits.
What pads would be best with stock rotors
Yellow Stuff is the common ones we sell for OEM Rotors, you can also do Ultimax.
Bumping this post, looking for feedback from those who bought a set from us! Seems like the GD Sport Rotors and Yellowstuff Pads are the most popular.
Green are more for daily and less noise? Yellow are more aggressive from what I read?
Sort-of, the Yellow is by far the best selling as it's better for towing and cargo and since these trucks are pretty heavy, you can't go wrong with the stopping power of the Yellow Stuff.
Bumping this as we have fresh inventory on most of these, 1-3 days to your door anywhere in the continental USA!
USR Slotted Style:
GD Sport:
I got the yellow and it didn’t stop squeezing was horrible atleast for me
I removed it cleaned the rotor reinstalled could not get it to stop squeaking with oem rotors
That is very strange, how did the OEM rotors look? Most our customers have upgraded the rotors at the same time so we have yet to hear this about the Yellowstuff pads.
Ive used yellow stuff on a lot of trucks, never had any squeek issues with them (yet)
USR Slotted Style:
GD Sport:
Bumping this post as EBC pricing is going up on 6/1/25! If you need a set of brakes, get them ordered up before them and use the forum discount code.
i got the GD rotors and yellow stuff pads, did the aggressive break in after 250 miles and definitely an improvement over stock, also changed out the brake fluid for higher temp fluid,,,, OEM rotors and pads were well heat damaged at 30K miles, hoping the EBC dont start the squeak,,,,lol
