You can do it either way. You just cannot do it fast because TRX’s do not like it and will cause false error codes and the shifter to stay locked.Serious question. What is the correct way to start the truck with igla? I got it installed about a week ago and I’m not sure if I’m doing it the correct way. I usually put foot on brake, fire up engine with start button, enter code after dash sweeps and then I can put into gear and go. Am I supposed to not start the truck before entering code? For example, put truck in run position, enter code, then foot on brake and fire up engine.
Also what do you do if you enter the code wrong the first time? Can you enter it again or do you have to shut off engine and restart the procedure? Happened to me once and I shut down truck and restarted. Did I have to do that?
Lastly, what’s the correct procedure for when it’s remote started?
If this is sensitive information, please PM if needed.
Thanks.
Get in, start it (if setup this way) let go of brake. 1. Enter pin, let it flash 2 times, drive away.
2. Press push to start 2 times. Wait a second, enter the pin, let it flash 2 times, wait a second, foot on brake and start it, then drive away
Let me know if you have any questions
Thanks
Josh
