How many miles on your TRX?
lordofsmolpp
Nevada
2021 RSQ8, 2019 GS-F F 10th anniversary, 2021 TRX
3 almost 4 months, 4,715 miles.
Absolutely love the truck and will keep it until I die.
My issues are as follows, I've written it out so you can see what each solution resulted in.
Issue: Loose fuses and relays (both panels) result in intermittent warning lights.
Solution: Push them back in.
Result: Resolved.
Issue: Electronic parking brake unavailable.
Solution: Dealer "adjusted and updated software".
Result: Resolved.
Issue: Error message, "T-case overheat message, performance temporarily reduce" multiple times under different conditions.
Solution: Dealer replaced t-case motor.
Result #1: Message persisted / issue persisted.
Solution#2: Dealer replaced t-case.
Result #2: Resolved for 1,250+ miles.
Issue: Driveline bump (observed consistently when stopping / felt under shifts in sport mode intermittently).
Solution: Dealer removed and inspected drive shaft, balanced and lubed if needed. Inspected and re-torque all suspension bolts to spec, spare tire checked, body mounts checked.
Result: Problem has become less noticeable & intermittent at best.
Issue: Read parking sensor ghost readings (not the brake assist issue).
Solution: Dealer did software update and calibration of sensors.
Result: Resolved for 850+ miles.
Issue: Sunroof wind deflector noise, making a "whistle" sound.
Solution: Dealer inspected and found that deflector was defective (mesh screen was unseated and could not be reseated). Dealer replaced part.
Result: Resolved.
Issue: Oil Temp above 270 degrees, Oil temp warning light comes on, reduces power and advises you to shut engine off for 20 minutes.
Solution #1: Dealer states no oil temp spec given by dodge, reads from the owners manual.
Result #1: Problem continued.
Solution #2: Dealer inspects oil temp sensor, states possibly defective, replaces sensor.
Result #2: Problem resolved. Oil temp sensor doesn't read / show above 265 now under similar conditions / use.
Issue: Passive entry non-functional on RF-passenger door.
Solution: Dealer inspected, passive entry magnet fell out of door handle and inside door. Replace RF-Pass door handle. back ordered from factory for 120-190 days.
Result: TBD been waiting 2 months.
Issue: Shifter produces a "clunk" sound when engine is on, vehicle is in park and the brake is applied to shift into gear. You can audibly hear the clunk if brake pedal is pressed repeatedly.
Solution #1: Dealer inspected, claimed normal operation.
Solution #2: Dealer inspected, confirmed the solenoid had issues. Replacement shifter back ordered from factory for 120-190 days.
Result #2: TBD been waiting 2 months.
Issue: HK audio speakers have static, rattle or white noise during bass heavy music.
Solution #1: Dealer replaced defective speakers / tweeters.
Solution #2: Dealer performed software update / reflash.
Result #2: Problem continued.
Solution #3: Dealer replaced select speaker wiring.
Result #3: Problem continued.
Solution #4: Dealer replaced amp.
Result #4: Problem continued.
Solution #5: Dealer created star case and escalation for assistance.
Result #5: TBD been waiting 2 months.
TRXJIM
TRX Noob
Ivyland pa 18974
Name
Jim
2014 Ram
Curious to see how many miles people have logged on these trucks. Also those with higher mileage have you noticed any wear or odd issues with your truck. I'm mainly curious how they are holding up considering all the little issues from factory etc.
Thanks for any feedback
I have 238..
Still breaking it in
scottn
DFW, Texas
2021 TRX Billet Silver
Convertible
Have had it since March. 3000 miles. Zero issues, but I think outcome would have been different had we not done thorough inspection to identify loose bolts and low fluid.
Ckemp3
TRX Noob
Texas
Name
Kemper
Trx
4 months 5500 miles. So refreshing to hear people excited to drive it. I’m trying my best to stay out of it so much so I won’t have high miles, but I can’t stay out of it.
just a dentist
florida
'16 JKU, '20 JLU, '21 rover
since feb 6500 miles. no issues, Knock on wood
Trxare4kids
TRX Noob
Oklahoma
Name
Delbert
2021 Trx
5600 ish and just had some intermittent TPS warnings (complete loss of signal)on right front and left rear seems to do it only while raining, other than that it’s a blast!
#TRXstillhope
Dallas, Texas
4 months, 7,000 miles…..rear parking sensors not working and the damn clunk on drivetrain….. other than that pure joy!!!
