have geiser springs on my truck over a year with no issues. did not recalibrate.
to fix the axle issue, you will need a panhard bar from Foutz. install at the same time as you put the springs on because both modifications require an alignment.
Ram TRX adjustable Panhard bar kit gives you options to re-center your rear axle after changing ride height. This kit is made from the best components. Johnny Joint forged 1" Johnny Joint rod end on the adjustable side and Johnny Joint uniball on the fixed side. The kit uses a 1.5" diameter...
www.foutzmotorsports.com
Ram TRX adjustable Panhard bar kit gives you options to re-center your rear axle after changing ride height. This kit is made from the best components. FK 1" rod end on the adjustable side and FK 1" uniball on the fixed side. The kit uses a 1.5" diameter chromoly tube to ensure the strength...
