Anyone else in the northern climate concerned at all about winter's road salt/slop/debris accumulating inside the front fenders' air curtain space? Or is it just me?
Yea I've been trying to figure out what they were trying to accomplish with the air curtain going all the way past the wheel....Every other car I have seen with an air curtain like the 2015 and newer F150 they are using the air curtain to go into the wheel well to try and reduce the rotational drag of the wheel and "smooth out" the air that is flowing around the sides just past the wheel...Anyone else in the northern climate concerned at all about winter's road salt/slop/debris accumulating inside the front fenders' air curtain space? Or is it just me?![]()
yea if you are like me a few times each winter on your daily driver you hose everything off and fog every bit of metal (except the brake rotors obviously) with WD40 to keep that salt at bayGood thing is they are not sheet metal so it should be more of an annoyance then a rust or rot problem, I’m hoping anyway
