JayRay
- Joined
- Feb 5, 2021
- Messages
- 869
- Gallery
- 30
- Reaction score
- 1,730
- Location
- Upstate NY
- Current Ride
- 2015 GMC Duramax
Would you have a picture of the factory oil filter and part number? ThanksView attachment 6988View attachment 6989View attachment 6990View attachment 6991View attachment 6992Hello all! I did the first oil change this evening at 1010 miles. I'll give everyone the executive summary of what I found. I followedwhat the TRX supplement said and was able to remove the dune guard without much fuss.....it is big, not too heavy. I checked the oil before I drained it and it was full. So....drained the main pan, and oil cooler.....the cooler took a good ten minutes to completely drain. The oil didn't look too bad, I included a pic ofbthst too that I passed a wrench through. The truck was warm as I just got home from work. Filter was on normally, not torqued on with a 3/4" breaker bar like some of the first changes I have done. I checked the diffs and the transfer. The ftont diff was very.low. I added close to a pint....it was over a 1/2" below the fill. The rear diff wasn't to bad, only about 1/3" or so below the fill. I included a pic of whst was left in.the quart of Mobil 1 that was left. The transfer was also about 1/3" below the fill too. I didn't have any transfer fluid so will top it off tomorrow. It's easy to access, the dune guard doesn't have to come off....it does for the front diff though. I checked all the trouble spots and didn't see anything other than a wiring harness connection that was very loose. The plastic grommet wouldn't hold it tight against the bracket so I zip tied it. Other than, everything looked good. Took me an hour or so to do everything, including 20 minutes of rolling around under the truck with a headlamp checking shit out. The front diff being pretty low was the only real issue that I found. Also, an update on the bad front driver speaker.....I figured I would look into it myself instead of spending 2-3 hours at the dealer. I bought a nice pair of JL 3.5's and decided to install one and see if it was definitely the speaker and not a channel on the amp. If it was tje amp, no big deal, because I need a set of speakers for the cab of my Kubota Grand L tractor. Well, it was the speaker so I soldered on 16 guage solid wire and press fitted the ends into the factory connection. Good as new....better, actually. The system sounds great! Now it just needs a stealthbox to be killer! Anyway, hope this shines a little light for those who are curious and for those waiting to get their trucks! Have a great weekend all.....time to suck down a little bourbon! Cheers!
I topped it off with Mobil 1 75W90 full synthetic. The manual says 80W90 full synthetic or equivalent. I usually buy a case of the Mobil 1 and have used it for years in everything. The 5 weight difference doesn't concern me, especially since I will be driving it during the winter!Thanks for the write up. I was planning on doing my oil this weekend or next, I think I’ll check all fluids as well.
What type of fluid goes in the differentials and transfer?
Haha! I'm not anal enough for that. Maybe if I was an owner/operator of big rigs....lolAnyone anal enough to send their oil in for lab testing?
Thought about it, I do it on my Cat ACert 32'sAnyone anal enough to send their oil in for lab testing?
I’ve seen people do it on exotics. Never done it myselfThought about it, I do it on my Cat ACert 32's
The Cats are on my boat, 1350hp each.I’ve seen people do it on exotics. Never done it myself
I wouldn't worry about it. If the thing blows up, its under warranty... Just saying.Outside of oil, my knowledge of what the best other fluids are is limited. Anyone care to list their high end favorites?
Did you get the 19 speaker system?View attachment 6988View attachment 6989View attachment 6990View attachment 6991View attachment 6992Hello all! I did the first oil change this evening at 1010 miles. I'll give everyone the executive summary of what I found. I followedwhat the TRX supplement said and was able to remove the dune guard without much fuss.....it is big, not too heavy. I checked the oil before I drained it and it was full. So....drained the main pan, and oil cooler.....the cooler took a good ten minutes to completely drain. The oil didn't look too bad, I included a pic ofbthst too that I passed a wrench through. The truck was warm as I just got home from work. Filter was on normally, not torqued on with a 3/4" breaker bar like some of the first changes I have done. I checked the diffs and the transfer. The ftont diff was very.low. I added close to a pint....it was over a 1/2" below the fill. The rear diff wasn't to bad, only about 1/3" or so below the fill. I included a pic of whst was left in.the quart of Mobil 1 that was left. The transfer was also about 1/3" below the fill too. I didn't have any transfer fluid so will top it off tomorrow. It's easy to access, the dune guard doesn't have to come off....it does for the front diff though. I checked all the trouble spots and didn't see anything other than a wiring harness connection that was very loose. The plastic grommet wouldn't hold it tight against the bracket so I zip tied it. Other than, everything looked good. Took me an hour or so to do everything, including 20 minutes of rolling around under the truck with a headlamp checking shit out. The front diff being pretty low was the only real issue that I found. Also, an update on the bad front driver speaker.....I figured I would look into it myself instead of spending 2-3 hours at the dealer. I bought a nice pair of JL 3.5's and decided to install one and see if it was definitely the speaker and not a channel on the amp. If it was tje amp, no big deal, because I need a set of speakers for the cab of my Kubota Grand L tractor. Well, it was the speaker so I soldered on 16 guage solid wire and press fitted the ends into the factory connection. Good as new....better, actually. The system sounds great! Now it just needs a stealthbox to be killer! Anyway, hope this shines a little light for those who are curious and for those waiting to get their trucks! Have a great weekend all.....time to suck down a little bourbon! Cheers!
Yes, I have a LE. Kinda shady they call it 19 speaker setup.....there's 12 speakers. I guess a single coaxial counts as 2 speakers.Did you get the 19 speaker system?
Does it sound good at least?Yes, I have a LE. Kinda shady they call it 19 speaker setup.....there's 12 speakers. I guess a single coaxial counts as 2 speakers.![]()
It does sound good, especially now with the JL's up front. The bass definitely needs more ass. The Bose in the GMC hits harder in the bass department. Hoping a stelthbox when available will help.Does it sound good at least?![]()
Well...shoot I feel like we've been had 19 speakers but only has 12 sounds ok if you change some speakers out... I mean WTF...if I tell my wife we have to do something to this truck after spending 90k+...welp I just bought the most expensive coffin ⚰everIt does sound good, especially now with the JL's up front. The bass definitely needs more ass. The Bose in the GMC hits harder in the bass department. Hoping a stelthbox when available will help.
Haha! I hear you. I like my music loud and I usually provide the tunes at bonfires and rural backyard shenanigans with friends....I wish the system went a little louder. A couple subs with a good amp will help though.Well...shoot I feel like we've been had 19 speakers but only has 12 sounds ok if you change some speakers out... I mean WTF...if I tell my wife we have to do something to this truck after spending 90k+...welp I just bought the most expensive coffin ⚰ever
