Someone made a thread elsewhere so I'm just copying it here for reference: https://www.ram-trx.com/threads/trx-with-leveling-kit-and-behind-grille-lights.1186/
Eibach posted a teaser recently of a TRX in and said lift spring kit in works.Personal, I have gone through this with my raptor. First I used the perch levels that came on the FOX shocks (Mid perch). The result was a slight stiffer ride around town, Less brake dive and better handling in the comers. (Remember Gen1 Raptor don't have electronic valving). I then went with Geiser Springs which gives approx a 2" lift and is progressive rate spring ride which provide excellent ride and better high speed off road capabilities. When I decide to level the front on the TRX, I hope someone has an aftermarket spring, which would be my preferred COA.
Good to know. Thanks for sharing. A spring replacement would be a great approach.Eibach posted a teaser recently of a TRX in and said lift spring kit in works.
i just talked to eibach again and here is what they said...Good to know. Thanks for sharing. A spring replacement would be a great approach.
