Pics please?I removed the foutz spacer and installed front only eibachs on friday. The ride is much better and seems pretty close to factory. Keep in mind I have had the foutz on since 500 miles so it has been awhile. I would say it sits pretty close to level and I am on 37's with no rubbing still.
Pics please?
Can you give us tire specs? Size, offset, etc? Thanks in advanceI removed the foutz spacer and installed front only eibachs on friday. The ride is much better and seems pretty close to factory. Keep in mind I have had the foutz on since 500 miles so it has been awhile. I would say it sits pretty close to level and I am on 37's with no rubbing still.
I just ordered a set from @Rouge Offroad this weekend and they had some in stockAnybody have these in stock?
Some people have a notion that collars are not as good as a replacement spring. I could see this if the collar introduced coil bind, but I do not believe that to be the case here. People also don't consider that high end coils all have adjustable collars, functioning the same as fixed pre-load collars. I assume the Eibach coils are linear rate, but I don't know what the actual rate is. Really surprised there isn't more info avail on the eibach website about them. At this point I am choosing to wait and hear peoples first hand opinion, as that is all the "data" we have...So, why these springs versus the Rogue level kit? I asked Rogue and they mentioned there really is no advantage. Anyone run one then the other and have any comments?
37x13.5x50 diesel power tiresCan you give us tire specs? Size, offset, etc? Thanks in advance
I agree with this assessment. I also don't mind the ride because I love the look. I still think they will settle and do well.The leveling springs are stiffer for sure .
Front end doesn't seam to move as easy as it did with the stock springs.
Like braking and accelerating. Not as soft of a ride, but I still like them plus no more fucked up lean.
If either provide any lift then yes you SHOULD get the recalibration done. Without it the shock system will always think your shocks are partially extended and react accordingly with the program changes. Would you feel or even know it, I doubt it at an inch or two of lift but I’m also the guy that has never felt any change from a cold air intake. LolI'm confused on that too. Why not with a level kit? Seems like they only talk recalibration on springs. Educate me!
