- Jan 14, 2021
- 194
- 23
- 341
- St Charles MO
- 2021 TRX - Hydro Blue
- Current Ride #2
- 2019 Wrangler (Hellcat Swapped)
all good! My Jeep is horrendous as well.
I got the "Demon Eyes" in my TRX. They look mean! However, the LED strips always stay on no matter what. Does anyone know a way of turning those off while driving? I only want the eyes to be on, rather than the eyes and the LED strips.
Hi, Did you install the demon eyes yourself? Also, how did you open up your light assembly? (Cut, heat and pull apart).I got the "Demon Eyes" in my TRX. They look mean! However, the LED strips always stay on no matter what. Does anyone know a way of turning those off while driving? I only want the eyes to be on, rather than the eyes and the LED strips.
Would love the details. PleaseHi, Did you install the demon eyes yourself? Also, how did you open up your light assembly? (Cut, heat and pull apart).
Removing material (Blade thickness) from the lense doesn't create seat issues when you put it back together?we've cut them all with our ultrasonic cutter. We've done thousands of other headlights in the same manner over the last few years.
Anyone who wants to bake their headlights on these trucks to open them up, I will warn you. It takes a lot more heat than I expected. I think I finally had to go up to 250 degrees for 20 minutes and it was STILL a pain prying that thing apart. I actually cracked a corner of one lens prying. Thankfully, it was on the part of the lens that gets covered by body trim.These lights are fun to work with. You can bake, if you have the patience for that. In the few hundred of the 19+ 1500s we've done - we've cut them all with our ultrasonic cutter. We've done thousands of other headlights in the same manner over the last few years.
Can't wait for a few parts to come in for mine!
I hadn't decided which approach to take, but I think you just made up my mind.Anyone who wants to bake their headlights on these trucks to open them up, I will warn you. It takes a lot more heat than I expected. I think I finally had to go up to 250 degrees for 20 minutes and it was STILL a pain prying that thing apart. I actually cracked a corner of one lens prying. Thankfully, it was on the part of the lens that gets covered by body trim.
In the beginning, I didn't want to use the ultrasonic cutter for the fear of removing material, but in the end, it would have been WAY easier and WAY cleaner. The hosing on my headlights is ALL bent out of shape and jacked up now. Looking back, I should have messaged @RetroShop and just let him know I have a set of headlights to send his way to do for me! Next time for sure, Retro!
Very nice! $$????Our location in Houston, TX just installed this kit for a Limited owner, he could not be happier with the results!
If you are in Texas be sure to check out ORACLE Lighting of Houston!
View attachment 20999View attachment 21000View attachment 21001View attachment 21002
How much to do the install if I just bring you the headlights? Or to do the complete install on the truck?DRLs are $199 a set and the Demon Eyes are $119 a set but forum members get 10% off with coupon code "TRXFORUM"!
Get yours here:
ORACLE ColorSHIFT Headlight DRLs
ORACLE ColorSHIFT Demon Eyes
If you are in Houston you can bring the whole truck to them and they can wire up everything set up your controllers, etc.How much to do the install if I just bring you the headlights? Or to do the complete install on the truck?
Any installers you would recommend in North Carolina?DRLs are $199 a set and the Demon Eyes are $119 a set but forum members get 10% off with coupon code "TRXFORUM"!
Get yours here:
Sure, put your zip code in our locator tool here and it will pull up installers in your area.Any installers you would recommend in North Carolina?
How long is the install if I bring my truck?Sure, put your zip code in our locator tool here and it will pull up installers in your area.
Store Locator | ORACLE Lighting
There are ORACLE automotive lighting retailers and installers around the world. Find one near you today.www.oraclelights.com
We also offer installation services if you want to ship your lights to us we can build them and ship them back to you normally with a 3-5 day turnaround.
