Custom Headlights
RetroShop
St Charles MO
Name
Jeremy
2021 TRX - Hydro Blue
2019 Wrangler (Hellcat Swapped)
all good! My Jeep is horrendous as well.
n8er
Minnesota
I got the "Demon Eyes" in my TRX. They look mean! However, the LED strips always stay on no matter what. Does anyone know a way of turning those off while driving? I only want the eyes to be on, rather than the eyes and the LED strips.
RetroShop
St Charles MO
Name
Jeremy
The only way to turn off the "signature lighting" feature is with a BCM programmer. Tazer DT would be a great option there.
We can get you one, I'm an authorized reseller for the Tazer products. They run $329 for them, and give a LOT of other features and functions as well. Feel free to email me - sales@retroshop.us - we can review!
Bavanew
Ontario, Canada
2016 F350 Platinum
Hi, Did you install the demon eyes yourself? Also, how did you open up your light assembly? (Cut, heat and pull apart).
topdawg4ever
Ohio
Name
John
21' Ram TRX Hydro Blue
18' Durango SRT
Would love the details. Please
RetroShop
St Charles MO
Name
Jeremy
These lights are fun to work with. You can bake, if you have the patience for that. In the few hundred of the 19+ 1500s we've done - we've cut them all with our ultrasonic cutter. We've done thousands of other headlights in the same manner over the last few years.
Can't wait for a few parts to come in for mine!
Bavanew
Ontario, Canada
2016 F350 Platinum
Removing material (Blade thickness) from the lense doesn't create seat issues when you put it back together?
RetroShop
St Charles MO
Name
Jeremy
No, we use an ultrasonic cutter, which uses a VERY thin blade. We trim the slag (minimal) before sealing.
No issues at all, we've done thousands (no bullshit) this way.
n8er
Minnesota
Anyone who wants to bake their headlights on these trucks to open them up, I will warn you. It takes a lot more heat than I expected. I think I finally had to go up to 250 degrees for 20 minutes and it was STILL a pain prying that thing apart. I actually cracked a corner of one lens prying. Thankfully, it was on the part of the lens that gets covered by body trim.
In the beginning, I didn't want to use the ultrasonic cutter for the fear of removing material, but in the end, it would have been WAY easier and WAY cleaner. The hosing on my headlights is ALL bent out of shape and jacked up now. Looking back, I should have messaged @RetroShop and just let him know I have a set of headlights to send his way to do for me! Next time for sure, Retro!
Bavanew
Ontario, Canada
2016 F350 Platinum
I hadn't decided which approach to take, but I think you just made up my mind.
RetroShop
St Charles MO
Name
Jeremy
Yeah, these are a blast! Most of the newer Fords, Chevy & Ram all use the same horrid sealant.......makes it fun for us. But, we've got our processes down to open and reseal.
Sucks to hear that you cracked a corner, but we've seen that before - and its VERY easy to do.....
ORACLE
ORACLE
Lighting Expert
New Orleans, LA
Anvil Launch Edition
Finally got around to getting some decent photos of the lights!
Get yours here:
ORACLE ColorSHIFT Headlight DRLs
ORACLE ColorSHIFT Demon Eyes
Forum members get 10% off with coupon code "TRXFORUM"! (y)
ORACLE
ORACLE
Lighting Expert
New Orleans, LA
Our location in Houston, TX just installed this kit for a Limited owner, he could not be happier with the results!
If you are in Texas be sure to check out ORACLE Lighting of Houston!
Caliche
Moderator
Staff member
Texas
2021 TRX
2018 Polaris 1000 Ranger SxS
ORACLE
ORACLE
Lighting Expert
New Orleans, LA
How much to do the install if I just bring you the headlights? Or to do the complete install on the truck?
If you are in Houston you can bring the whole truck to them and they can wire up everything set up your controllers, etc.
We are at the main location but give the Houston store a call directly for a quote:
9826 Clay Rd · (713) 234-7750
ORACLE
ORACLE
Lighting Expert
New Orleans, LA
Any installers you would recommend in North Carolina?
Sure, put your zip code in our locator tool here and it will pull up installers in your area.
We also offer installation services if you want to ship your lights to us we can build them and ship them back to you normally with a 3-5 day turnaround.
Caliche
Moderator
Staff member
Texas
2021 TRX
How long is the install if I bring my truck?
