I did and replaced tired at 20k a well. Mine i think was also self inflicted. New tires have about 3.5k on them and look normal.Anyone having cupping / scalloping of there tires
Rotate every oil change.Anyone having cupping / scalloping of there tires
I replaced OEM tires at 66k. Never any issues. Rotate every 5k and keep inflated to 50psi.
What's wrong with running 50psi?Damn, 50 PSI...why? Your truck must ride like a Conestoga wagon. The recommended pressure is 38 PSI and max is 50 PSI. I run 32-33 PSI and don't get any cupping.
I’m running 33psi. Just smoother ride but surprised running 50 didn’t wear out middle tread quick.What's wrong with running 50psi?
Common? No not so much, very rare in fact.This seems to be a very common issue with the original brand tires on these trucks. I just started noticing some wear on my tires and has them rotated. As far as I know keeping up on your rotations is all you can do.
That's one good thing with radials, well, belted tires. They really can't change their shape (circumference) much because the belts don't allow it.I’m running 33psi. Just smoother ride but surprised running 50 didn’t wear out middle tread quick.
