smontoya
TRX Noob
Do you have a video of you programming the truck to accept the new button? Did you have to call the dealer to add the code to your vin? What’s the correct code?Updated video is back up now.
I don't have a programming video unfortunately and the dealer no longer has the ability to do it, so the only way is to use Alfa OBD to program.Do you have a video of you programming the truck to accept the new button? Did you have to call the dealer to add the code to your vin? What’s the correct code?
Hey, the instructions I laid out are pretty good. Don't sweat itDo you have a video of you programming the truck to accept the new button? Did you have to call the dealer to add the code to your vin? What’s the correct code?
I 2nd RobsTRX answer, his write up is pretty awesome and should get you through it just fine.Do you have a video of you programming the truck to accept the new button? Did you have to call the dealer to add the code to your vin? What’s the correct code?
Hi,Did you remember to turn the truck on and of to reset the computer before moving the vehicle? My dash lit up and I had to do a reset as shown in the instructions
Yes if you have the taser you don’t need a separate security gateway bypass it acts as one.Can you do this if you are already running a Tazer?
Alright so if I already have a Tazer, I don't need to order that Kaodtech security module bypass? I can just have the Tazer plugged in and then plug the OBDII Link directly into the truck, make my changes with Alpha OBD, and then be on my way?Yes if you have the taser you don’t need a separate security gateway bypass it acts as one.
It works. Seems it just needed time to re-downloadI have the switch installed, haven’t programmed yet. I disconnected the battery. When I hooked it back up I lost XM in the media source menu.
When I first turned the truck on it wanted an anti theft code. That flashed and went away and truck started and drove as normal. I’m not sure if any of this is related. Anyone have an idea?
What’s the part number on the switch? I looked through this thread but I didn’t see it.
Thanks
Yes that is correct. I did it on my 22 with just the tazer and OBDII link.Alright so if I already have a Tazer, I don't need to order that Kaodtech security module bypass? I can just have the Tazer plugged in and then plug the OBDII Link directly into the truck, make my changes with Alpha OBD, and then be on my way?
I'm not seeing anything that says the security module bypass requires anything other than to be plugged in... All the changes look like they take place on the Alpha OBD II software and the OBDII Link. Just wanted to confirm that all I have to do is plug in the tazer to get this working. No extra steps since I don't have the Kaodtech security bypass.
I have the tazer already installed. So what exactly do I need to complete this? Very interested!Yes that is correct. I did it on my 22 with just the tazer and OBDII link.
