I have to start by thanking the people who helped get me here. Taylor potter for making the switch install video and going far enough with it to show it will actually work and for me the member DUSM that helped by showing what prompts in the program were changed to make it happen. I actually have to thank my RAM dealer because if they didn't suck so fully I may not have had the drive to prove them wrong and start fiddling with my ECU. Something I know nothing about
Now that I know how to do it it's really simple. I will provide links and photos below
Installing the switch
Watch potters install of the switch. It's very straight forward. He did an outstanding job with the video. For me I found that I just needed to be patient fiddling around to get to the tabs to release the air bag the rest was easy. Listen to what he has to say. You need to come threw the holes in the steering wheel at a slight angle to get them. I'm really mechanically sharp and it frustrated me. I actually used a Philips screw driver. Take your time with this project. Worst case scenario any local garage could install the switch.
The programming. For a lot of us this is unchartered waters
You will need to buy a OBD link MX+ and a security bypass (links below). The security bypass has 4 plugs. One gets plugged to the OBD port one has what will be your new OBD port that you will plug the OBD mx to and 2 small plugs that get plugged into 2 different circuit boards under the dash. (No worries the adapter comes with good instructions, its a snap to install) I had a fellow member tell me a good hint. Remove the tabs that hold the 2 small plugs in. (Photo below). It's not a terrible spot to get the plugs into but getting them out would be tuff and there's no reason to keep it attached after your done. You'll see this immediately as you do it.
Then do not make the mistake of trying to use the software that comes with the OBD link. Like I did. You must download and buy alphaobd, link below. Its the key. Once the program is loaded follow the instructions on the alpha obd website to buy and activate the program. Easy peezy. Support is quick to respond if you have issues
info@alphaobd.com.
After you have activated the program go to the first tab "start" Put your vehicle information in and you will need to connect to the OBD link. Click on connect. (shown in photo1) a box comes up with the link on it. select it (photo 2) once that is done the program starts the connection to your truck and when it's good on the upper right hand side of the screen the red status will go from idle to connected
Next you want to go to the tab status/faults. You want to be sure the tab save log is checked. There's nothing worse than making an error and not remembering what you changed. just below that theres 2 tabs that bring up the changes you have made (photo 3)
The programming, click on the tab "active diagnostics". Its the one that has he car hood up, click on the open box and you get a drop down. Go all the way to the bottom. There are 2 important items. the first is car configuration change and ECU reset. To make the necessary changes click on car configuration changes. If you screw up and can't figure out what you did wrong by going back to the log you can use the ECU reset to start fresh (like I did 2x) (photo 4 below)
When you click on car configuration you will get a search box, type in cruise control and the cruise control parameter will come up. Under that it will give you to option to turn it on or off. It will be currently on, you need click it to off (photo 5) then hit the start prompt just above it. It will tell you when it's done.
Next search ACC and the adaptive cruise control will come up, change the setting to ACC with stop and go. Like before press start and the changes will be made and the program tells you when it's complete (Photo 6) Don't put the truck in drive to test it. (I have been tole the cruise has to be off before turning on the ACC) I made that mistake and it sets off the collision avoidance system. Shut it off and allow the setting to take in the computer. The program says to wait 30 sec. I actually got out and allowed the truck to go dark. Then fire it up and your ready to go. Remember if you have an issue, at the bottom of the list just under control settings is a ECU reset if you screw up. No worries. I had to do it 2X
When it's all said and done my dealer said he would do it for $175 and decided not to and waste my time. He said it's not possible. I can tell you I'm a techno nothing and got it. In any case you can do it yourself for close to that, in less time then it takes to deal with them and have the satisfaction of giving the dealer noting but the middle finger.
I'd like to say I appreciate this forum and what it brings to me and others. I'm glad to contribute!!
The OBDLink® MX+ is the top-of-the-line OBD II scan tool to use with forscan and comes with bluetooth. Get one here today and gain access to your vehicle!
www.obdlink.com
If you have a 2018+ RAM and would like to perform diagnostics or make changes to the modules of your truck using tools like AlfaOBD or AutoEngenuity, this bypass is for you.Does this allow access to all modules?It has been tested connecting to the BCM and RFH. Since it bypasses the security...
www.kaodtech.com
