Car Lifts
Imaposer
ohio
2022 TRX - hydro blue
2022 TRX - Hydro blue
How wide is the trx outside of tire to outside of tire? The advantage has an adjustable width, but the second set of holes is narrower. I don't think it would be a big deal to add a set on the other side and move it out a bit further. The other option I would consider is getting plates made that would go under the tires that extend out 6" or so on the outside with gussets underneath just to provide support under the whole tire. I'd rather do that than buy a gigantic lift that's really not needed.
Imaposer
ohio
Well shit. That's barely any overhang as is. I'll have to look and see what it would take to move the adjustable side out 3". Worst case, I'll get some 12"x16"x1/4" steel plates and park on top of them if I ever count on putting the trx on top for an extended amount of time. Of course, I need to buy the land and have a garage built with enough overhead first.
Tom488
New Jersey
It's about 50% overhang. The Advantage is 75" outside-to-outside on the tracks. That's 6.5" of overhang on each side.
l2azorback
Little Rock, AR
2022 Ram TRX - Billet Silver Metallic
I have the Advantage Lift in my Garage. I have 10-foot ceiling, so the TRX won't be going on it, it could, just not very high. I keep my 1969 Camaro on it. Very easy to assemble with good Youtube videos (watch to save you time having to stop assembly and go back to watch it). If no mechanical lifting device, have at least 4-5 strong lads to help with assembly. FYI Advantage is the ONLY chinese lift with ALI Certification. I got a great deal on mine (car show pricing) last year during black friday. I also purchased the air over hydraulic jack. Would recommend two for the TRX. Advantage does make a heavier lift for trucks.
Imaposer
ohio
Shit. I can't maths. I thought it was 85.
That Guy
Arkansas
07 Escalade ESV,97Ram3500
20 Challenger Hellcat Redeye , 67 Shelby Cobra replica , 06 HD Street Glide , 16 Kawasaki KLR 650
Northern tool has this one in a mail catalog
Tom488
New Jersey
All of the Bend-Pak lifts show a runway width of 75" or so - same story as the Advantage lifts - the TRX tires will hang halfway off the tracks. Since these are all cable-and-pulley lifting designs, I believe the runways are fixed to the crossbars, so I don't think they can be slid further apart.
ETA: Yes, just read through the installation instructions. The runways bolt to the cross-tubes, so the width is fixed:
Bolt the Powerside Runway into place, two Bolts on each end going into the Crosstubes. Use four M12 by 1.75 by 90 Hex Head Bolts.
On my Eagle lift, the runways can be positioned anywhere along the cross tubes - they just "float" on the crossbars. I've slid them completely together to lift a lawn tractor (about 36" wide), and I've slid them apart to accommodate a DRW 1-ton pickup (about 98" wide).
Finding a 4-post lift that's both tall enough to clear a TRX underneath, and wide enough to comfortably lift one, is a bit of a trick.
Bod89lx
New Glarus, Wi
2019 JL Rubicon
2021 GT500
You may be better off having your wife park under the lift with the Porsche on it. That will make getting a lift that will work with the limited ceiling height.
Bod89lx
New Glarus, Wi
2019 JL Rubicon
2021 GT500
I have 14’8” ceilings and my Ram 3500 wouldn’t fit under a standard height lift. Here is the clearance with my car on top and my Jeep under it.
Two
TRX Addict
The actual Midwest
Too many to list
Yep, a TRX would fit on my cheapy (outdoor) 4-post...if it wasn't for the little boxes at the lower inside corners that protect the pulleys.
But it would be really close, as even with a regular 1500 the mirrors must be folded in to fit between the posts.
l2azorback
Little Rock, AR
What about the Advantage 11000 truck lift?
Tom488
New Jersey
85" track-to-track, so the tires will only hang over an inch or so, but the drive-under height is only 81" - JUST a bit short to comfortably clear a TRX. It might clear, as they advertise two different clearances... in one place they say 81", in another they say 82".
l2azorback
Little Rock, AR
And if you use the rubber landing pads, it gives you and extra 1/2". I have mine this way, and don't even have to bolt my lift to the floor. Very solid and doesn't move around
