Bwoody on my TRX
Chrisbo
TRX Noob
New York
2023 Ram TRX
The sound is intoxicating.
Well done. See you got the right filter from start. Good move.
Just a tip:
Zip tie your air intake sensor wire to the nearest hose. Make some slack on the sensor wire and zip tie it so it is facing perpendicularly to the tube. I can see it is getting tugged away from the port in the pic because the OEM sensor wire is a bit short for the longer Bwoody tube.
If that sensor falls off you will get some codes.
Like this:
